Hey Everybody,
Here goes. My clutch grabs in first at lower RPM. When I use a little higher rpm to get the truck going it's not as bad. Was a little better right after I bleed the system. Checked the outside of the system, MC, slave lines etc.. and can't find a leak.
The clutch was changed by a Toyota dealership about 25,000 k's ago.
The clutch may be the source of a squeal I hear when out 4x4'ing, low and first gear and coming out of deep cross ditches or walking the front tires over rocks.
What needs to be done to visualy check the clutch?
Where should I start ?
