clutch help needed!
So Cal
I have an '82 Toy truck 4x4 that has given me no problems until recently.
My clutch pedal drops to the floor without effort and upon inspection the slave on the transmission is spooing fluid. Replaced that and now I think the master cylinder is bad also. What are the chances of both going out the same time? Pumping pedal to bleed air outa the system doesn"t seem to push much fluid.
Thanks,
Matt
Actually, both going out together is fairly likely. Consider that the seals will be about the same age, have the same wear, be exposed to the same fluid, etc.
