Cluster
mexico & USA
Hello Friends
Does any know how to make a loose cluster gauge lamp base tighter since it is lightly loose and turns on the light whenever I push it with my hands and when set it free turns off.... in a few words it is short fuse..
The base at bottom is similar to the RPM light that has the short
How do you name this light base? I need a spare one to replace the loose one.
enclosed is a picture of the base I need to replace or fix
Page 20 of this thread has all the bulb types (LED and standard) and where they fit. Definitive led thread for 80s
The aftermarket leds I’ve purchased all seem to have a thinner base and cause the issue you mention. I usually swap the leds into the factory base they’re replacing.
You could also stick a small screwdriver or pick Under this wire and gently pry up a little. It would make the bulb fit in a little tighter.
Thanks for your reply
