Clunk when disengaging cruise control
Traverse City, MI
Website
www.myspace.com
I just noticed this today, but if I tap the brake when using cruise control I hear a noticable clunk. This is only under load. If there is minumum load on the engine there is no noise. Is this just driveline slack and "normal" or something I should be concerned with? :confused:
cruise clunk
I have experienced that as well. It nly seems to happen when you hit the brake.
I suspect that it is the Cruise Control dumping the throttle instantly when the brake is applied. The greater the load the more throttle applied by the cruise control and there for the further the thing has to go when released to get back to its stop. Haven't looked inside the unit but I suspect that there is a decent sized spring in there to return the throttle to the idle position. If you follow the cruise control with light throttle pressure and then touch the brake then the clunk will not be there.
I also get the clunk when the cruise control gives up trying while climbing big long steep hills sometimes.
Seems like something that is normal.
Clunk
Well it would be driveline shunt but the noise comes from the inner fender where the cruise control module is located.
Is that where your noise comes from p8nt??
I honestly cant say ive narrowed down where the noise is coming from, Im going to try play with it a bit more today. I can say that this only occurs with cruise control on. Under load and at speed, I can spkie the throtal repeatedly and not reproduce the noise. Only when braking from cruise control.
Whats driveline shunt?
It's the infamous 'clunk' with most 80-series Land Cruisers, most noticeable when shifting from Reverse to Drive/vice-versa. Also noticeable in some when flooring it and suddenly letting off the gas.
oh, ok. Can it be serviced? Or is it just one of those things that you forget about and move on?
Clunk
I'm telling you it is the cruise control dumping the throttle when you hit the brake.
It is NOT drive line shunt or free play if you can't get it to happen with throttle input.
If it ONLY happens with cruise control it has to be cruise control related.
I believe that it is a normal thing that happens only when you touch the brake while the cruise control has a large throttle opening applied.
If you can narrow the location of the noise to the area where the cruise control module is mounted, then move on.
Cheers
Figured it out
Are you ready for this.....the noise was the gas pedal slapping back to the ready position when the cruise would give up control. :doh:
Right your were major, I still want a definition of "driveline shunt" though :flipoff2:
Driveline shunt is, to my understanding, technically the free play that exists between the engine output and the wheel. This is the sum of all the little tolerances and gaps between every gear, etc.
The effect is that a quick change in torque or direction (IE on the gas to off) which causes an inertia gradient in the driveline will produce a nice "clunk" sound and a small jolt through the car as all the various parts of the driveline spin through those slack points via momentum and experience impulse forces. The mass of the driveline components also affects how pronounced the effect is.
It could be considered a component of driveline slop I guess....
Thanks Nate, well put. So in the event of driveline shunt, we just grin and bear it. nothing else to do short rebuilding the vehicle from the ground up :D
Also, thanks again for your efforts in creating a streamlined process for downloadsing the FSM. For someone not framiliar with wget, you made life a whole lot easier.:cheers:
