Clunk on brake application
Kennett Square, PA
Website
cruisin4parts.com
This problem is hard to reproduce, normally happens at a least expected time. But out of most of the times its happened, its been after a bumpy road or after driving through snow.
What happens is, as once I apply the brakes, I hear a clunk as if the parking brake was engaged and the car jerks to a stop suddenly then unfreezes and starts to slow down at the normal pace...
The first time it happened, it was really cold and the night before I did some snow driving. As I went to put the brakes on at the top of my dirt (and pot-hole filled) road, it happened. As I tried to pull away, some wheels skidded because they were frozen while others pulled. :confused: I pulled over and stopped, then the freezing went away. Ever since then when I get the clunk it comes right unfrozen, but it sure does jerk the car!
I'm really not sure what this could be. From the sound of it, its one of the driveshafts freezing. :confused:
Things to note:
- I did repair on my front DS, I swear I should have marked the correct alignment, but dad said it didn't matter.. so it could be unbalanced, but it is in the correct phase. This was done like 5,000 miles ago.
- My brakes are pretty worn out.
:o
Have you checked to make sure the bolts holding the calipers on are tight (and not missing)? Not sure what else to check but I wouldn't think driveshafts would have anything to do with it.
When you say a wheel skids, do you mean it doesn't spin even when the vehicle moves?
aaron
Ok, we'll see if it happens when I get my brakes redone.
Yeah, the skidding only happened once. One set of tires did NOT spin. Not sure which, I just know some were not moving even though when I was pulling forward. Could have only been one tire, which plays into the brakes problem.
