Clunk on Acceleration
Cool because I did all that last night, Thanks for the info brother. I always worry about greasing the splines too much or too little. Ive gone through some driveshafts over the last couple years and a lot of miles. so my DS are always something im concerned about.
I wouldn’t install a zerk in the splined area. In fact, I install plugs where the factory spline zerks are installed because they get broken off. You do a lot of wheeling so not a good idea. My Driveline maintenance involves removing the drivelines for inspection as well as lubing. On the bench it’s easier to lube the centering pin of the DC joints and you can pull the slip joint apart for cleaning and precise application of lube. Once per year is enough unless you use that snorkel every trip.
Shiite man I pull the front every couple thousand and lay it on. wha is the correct lube for this. These were brand new for toyota not all that long ago and I dont want to trash them from not keepin em greased.
I use valvoline palladium grease everywhere. The spline joint needs only a thin, even coating. Grease does it’s job on a microscopic level. There is also the concept of dirt and water proofing gaps with “plentyOgrease”. There is no purpose to a pound of grease in the female spline cavity.
