Clicking when turning + accelerating - not birfs?
MDarius
I break stuff.
Bountiful, UT
I had my front end serviced this summer: Birf's and bearings repacked, etc. Now I recently noticed that when I turn from a dead stop, like turning right from a stop light and you need to get out of the way fast, I hear some faint clicking from the front end. It reminds me, although much more mild, of my '86 Cherokee when the U-joints needed to be replaced. I just had the service done...could it be something besides my birfs?
I have that too in my 95. Assumed it was the birf's (haven't had time to service them yet), but maybe it is something else. Let me know if you find out anything.
Same issue in a 94, had it for year only when I punched and turned. Im kind of have bad hearing but it seems like it might be out of the transfer case? unloading or biasing front to rear. I'm sure somebody knows.
Transfer case was a thought I had also. My Jeep had a chain that would slip and click under pressure and it sounds just like that, but these TFC's are different. I'm anxious to find out what it is, because it wasn't there a month ago.
u-joints have been known to click and maybe the extra load of the front tires being turned is what is bringing it out.
So...some clicking is normal, don't worry about it?
I'm going to check the levels in the birfs to make sure they filled them properly. I took it to a non-Toyota mech. and gave them the FSM as well as the FAQ writeup from here, but it's possible they ignored it all, greased 'em and put it back together without filling them up. 3-4 months of driving like that and it would make sense that they'd start to dry out.
I hear the same on my '91. Could be that the service guys did not lube the birfields properly and you have experienced a little wear. This also happened to me. Then on a hard turn, when they're under most stress, you hear clicking or popping.
One other thing is proper wheel bearing torque. If they did not get it right, there could be a little slack and causing extra strain on birfs on hard turn. This would be easiest to check if you have a torque wrench and proper sized wheel nut socket. You can check the preload with a fish scale. I got this from another thread.
- Tighten inner nut to 43 foot pounds and turn hub 3-4 times each way.
- Re-torque again to 43 ft lbs.
- Then loosen nut until hand tight.
- Torque 48 INCH POUNDS and check for no play.
- Check preload....should be between 9 and 12.
- Install lock washer and tighten outer nut to 47 FOOT POUNDS.
- Check preload
Clicking is not normal. The u-joints need to be replaced. I had the same noise, and a little vibration. U-joints fixed it fine.
I tried to replicate it last night and could only get it when I turned right. It sounded more like it was coming from the back end and it was kind of a dull ''tunk--tunk-tunk-tunk-tunk'' lasting only a second or two, and as long as the suspension was travelling from body roll...which is also as long as a hard turn takes, so inconclusive there. The sound made the same pattern each time I was able to duplicate it. Does this change anything?
If the service was done by a non-toyota shop and you didn't actually see them pack the birfs I would be very dubious of how it was done and what was used. I think I would be tearing one of those boys down and taking a look for myself.
The only conclusive way to determine the source of the noise is to have a friend drive while you lay on a creeper under the truck and hold on. Better yet, have a not-so-good friend on the creeper while you drive.
Lube the creeper wheels very well before doing this so they can handle the necessary speed. Stay away from the drive shafts and wear tight clothing. You may have to move around to several places in order to pinpoint the source of the noise.
This is best done at night on rurual roads to avoid problems with government officials.
THIS IS A JOKE - ONLY AN IDIOT WOULD EVEN CONSIDER THIS! I can't believe anyone even read the whole thing without blasting me.
:confused:That was helpful:confused:
Anyhoo, you can check the ujoints easy enough before you tear into anything major. Check for play in the joint- there should be none- and maybe grease them up while you're down there. If that doesn't fix it for you, then look at your birfs. It is possible that they were toast before you had the front end serviced and no amount of grease will stop worn out birfs from clicking. Were they cliking before?
I thought it was funny, Meischa. I'm waiting for the YouTube ''How-To'' video.
The birfs weren't clicking, I had weapy seals and my Axle fluid was mixing which is why I had the repair done. It hadn't been going on for long, thanks to the heads up from other Mud members.
I've been sick, so as soon as I'm feeling better AND I get a decent weather day I'll take a closer look. I did run a finger across the birf housing and it's dry, not lubricated so I'm thinking I need to take a better look soon. We're not driving it between now and then.
Come on man, it's kinda fun. Though 'someone I know' did it using a longboard skateboard. :flipoff2: :lol:
Awwwright, I need to lighten up a bit. I'll work on it, uhhkaay?
Open the top plug on your knuckles and check how much grease is in the knuckles. Fill them as Toyota says they should be filled with molly grease. Been there, done that, fixed my problem.
I don't mean to sound evil or anything, but pumping grease from the fill plug will only make you pump grease out your seals. That grease will never make it to the birf.
See this:
attachment.php
I was about to---
See this:
attachment.php
The grease goes into the "chamber" on the inside of the birfs, correct? ie: between the seal and the birf.
So some of it will get into the birf cage, balls,etc.
Correct?
g
