Clearance Clarance?
Oklahoma
I'm getting ready to do a PS conversion on my fj40. I have read a lot of the old threads to get some pointers and advice. I am thinking about using the saginaw conversion even though I'll never run anything larger than 35's (anything bigger won't fit in the garage). The problem that I'm worried about is a clearance issue if I did choose the minitruck conversion. Would I have any issues with the clearance of the shaft for a saginaw? The PO installed a 350, so here are some pics. Let me know what ya'll think.
Zac
Not gonna be much help here cuz I haven't done a mini steering conversion. But, from the looks of that motor mount placement, conventional thru the front frame Saginaw is out. How about a Scout Saginaw box? More beefy than a mini or 60 box. You'll prolly have to add an angled front corner frame brace (just below the radiator) for it though.
i have the same set up in my 40, and yes the saginaw set up will work fine. you will have to trim just a little off the moter mount for clearance but no big deal the part you need to trim doesnt support any weight or anything. i have had mine in for about 3 years no problems what so ever. just follow whats in the tech section, i think i went by the one rice did if i remember right. i used a 3in. hole saw to cut threw the frame cross member on both sides for the steering gear box. its so nice to turn the wheel with one finger. i am not sure but i think the mini would hit the exhaust. good luck.
I vote for a scout box as well. You'll have more room around the exhaust manifold, and it's a much cleaner install than the typical saginaw setup (I don't know why those are so popular.)
My guess is because it's tried & true & it's the first option anyone thinks about, until they browse the MUD tech section. I did the Scout box on my 55 & it worked out great. A little steering shaft fab work, but it looks *almost factory.
IIRC, any box from a scout II will work, but the input shafts are different. I think one is 3/4" and the other is 13/16s? One is more desirable than the other because of U-joint availablity (or atleast this was true in 2001 when I did my swap.)
I did the Sag box during my SBC swap. I did have to trim a little off of the frame rail when I did it. Here is a pic. I probably didn't have to reinforce it like I did, but made me feel better. It was only 1/2" or so off the frame.
70 fj40 with sbc , ramshorns , saginaw p/s up front , other than cutting crossmember and cusomizing end of original shaft with u joints from rodtech nothing hits , close to frame but clears , manifolds , motor mount , you should have no problem , but after looking at some the scout may be best , easily serviced ( i.e. replaced when stuck ) line routing is easy , more winch options ....
