Clear angel eye headlights
Formulaonehd
NWZ - The storm is here
Pilbara Region Western Australia
couldnt see anything in the searched threads about these headlights but just installed a set of clear angel eyes and pretty darn happy with the outcome . Bright at night and good peripheral coverage . Had seen a set of the black angel eyes and thought they look good on lighter colour trucks .
Put up a few photos for others
I think those are typically referred to as HID Projector lenses...
Yes and no. They are projectors, but only the low beam. And unless they are different that the ones I have (SONAR brand - they look identical except mine are the black ones) they are NOT HIDs unless they've been modified. They're just standard halogen projectors that will handle an HID bulb very poorly (scattered, unsafe light pattern). But, if done correctly with a complete HID projector retrofit they'd be pretty decent lights.
I replaced mine with Depos because the SONARs developed a water intrusion issue that killed bulbs. They could likely still be resealed and used, but I decided the look wasn't for me. Also, the rubber gasket that surrounds the light housing never stayed put, and the fit and finish was just alright.
Is the low beam focused so as not to blind incoming traffic?
The ones I used actually gave a very nice, clean cutoff and good light spread (with standard halogen bulbs of course.)
Yeh ow beam has the opaque lens projector with high beams the usual gloss reflector (not sure of the technical term for this )
