Cleaning evaporator questions
Maine
First off, I have searched. Below are pictures of what my evaporator looks like. Pretty clogged up in the fins. It seems to be an oily residue, mixed with dirt and maybe pet hair. I know a couple of people have used the BK Frigi-clean I think it was, as well as the Lubegard Kool-it. I barely have any smell, so that is not my main concern here. Getting it clean is, so as to improve the airflow, as it seems it could be better. So I am looking for real world experiences in this. Did you see it dirty before as I have, then looked later and it was cleaner? Just wondering if these foaming cleaners do a good job or not in the real world. And if you have any other product recommendations, that would be great also. Thanks.
I would like to be able to clean it on the vehicle without removing it if I can. The soft brush might work. Who knows what this car has been through. It has a salvage title and has been flooded. I
I use one of these
Thexton THE467 Radiator/Condensor Cleaning Wand
There was a post a year + ago about folks using these with good results. A LOT of nasty crap came out of mine. If you take off the grill you can get to the front side of the radiator and condensor and the back side of the condenso. If you remove the radiator cross bar you can get to the back side of the radiator.
Mine wasn't near as nasty as yours though :eek:
I would think a good degreaser, soft brissle brush, and then the "wand" above would do wonders for you. Can be done on the rig. Of course it goes against what Gray said about NOT using high pressure spray :hhmm:
Oh, and they even make radiator "combs" that you can use to straighten out the fins. Never used one so no idea how well they work.
If you take off the grill you can get to the front side of the radiator and evaporator and the back side of the evaporator. If you remove the radiator cross bar you can get to the back side of the radiator.
Good suggestions, but you are thinking of the condenser on the front of the radiator. I need to clean the evaporator which is tucked inside the heater/ac box up under the dash. Good degreaser like you said might be worth a try too.
Yep, I am. I even typed "condensor" and went back and changed it to evaporator thinking I was confused :D
I guess my confusion was those pics are of the evaporator INSIDE the rig and I was thinking it was of the front (outside) of the rig - That is nasty looking. :eek:
Looking at that picture and now knowing where that part is sitting it almost sounds like it would be a very good idea to tear it apart. No telling what other nasty stuff might be hiding. Is it a Katrina rig?
Since his rig has already been "flooded" once I don't think he is using any high pressure water inside the truck to clean this :) :lol:
Gray, were you thinking this was stuff on the outside of the vehicle as well?
I would agree with Corsair, you should really tear that thing apart. I have seen flood vehicels before (Grand Forks ND) but I have never looked at the condenser under the dash.
Frankly, I would take the vehicle and strip the interior and clean everything. Can you verfiy that the interior components have been replaced since the flood? If not, you should really consider replacing all of the "soft parts" and thoroughly cleaning the hard parts.
I had a 1970 Mote Carlo that was flooded and due to the contaminants in the water it was not cost effective to replace all the parts so I ended up selling it as a drag car.
That is extremely clogged and like posted initially the products are good to try and they work but once again I haven't seen one start at the level of dirty. I looked at that wand and for your application (interior) I do not believe you can control the run off adequately. I believe what the wand does it limit the pressure through the nozzle therefore reducing the outlet pressure to allow use around the softer material of radiators.
If you are adamant about not pulling it I would suggest a good aluminum cleaner (some of the foaming engine cleaners are aluminum compatible) and a small bucket and sponge. This will be a long and arduous event (not to mention great for your back).
Glen
No, but it was in Houston during a tropical storm in 1998 if I remember right, so who knows how bad it was.
I would agree with Corsair, you should really tear that thing apart. Frankly, I would take the vehicle and strip the interior and clean everything. Can you verfiy that the interior components have been replaced since the flood? If not, you should really consider replacing all of the "soft parts" and thoroughly cleaning the hard parts.
Glen
I may end up tearing it apart, we will see I guess. I have gone through almost all the interior now, and all is good. Had to fix a lot of wiring goofs, and other misc. stupid stuff from PO and previous mechanics, mostly minor issues. Car has been running fine since it was rebuilt 8 years ago. MANY things in the interior were replaced after the flood. Guess this would be the ultimate test for some of those foaming evaporator cleaners. If I try them, I will be sure to say how they did.
corsair23; Yes, I totally misread the original post; thank you for the gentle nudge. Going back to sleep now.
You weren't alone on that :D
So I am back to thinking about cleaning this again as I got my system recharged, and it is kind of stinky with the summer heat and humidity. Can you remove just the lower half of this evaporator box to access the evaporator? Or does the whole box have to be removed to split it? Thanks in advance.
Be carefull on what cleaner you use even if it´s aluminum friendly.
Last week I had a talk with the tech people who were cleaning my shop big A/C unit which had the condenser and evaporator clogged and they were against any commercial foam or liquid cleaner.
If not well washed and removed after 20 minutes it will damage for life the fins and tubes no matter what the sticker say. And they do this for a living.
On my A/C they used a low pressure low temp water steamer and carefully monitored the pressure to avoid any damage to the fins.
Last condenser I cleaned was on my brother´s in law FJ-60 and we used a 2.5 gallon gardening sprayer filled with water mixed with a small amount of kids hair shampoo. The pressure is quite low and we could keep a nice flow enough to clean it with a small brush. Tedious work but we removed all the dirt, later we flushed it again with plain water using the same sprayer.
Mine was far worse than yours. I cleaned it with mag wheel cleaner.
It is now awaiting a trip to the recycler.
It developed a pinhole in the middle of the cores. Took a lot of dye to find it. I'm blaming the cleaner.
I haven't used BG's Frigi-clean yet. But now that I have a gently used evap, I'm probably going to start using it.
It's a preventative maintenance product. So I'll shoot it on my evap at the beginning of every summer.
(I trust most BG products. I use many and have yet to have a single one that doesn't do exactly what it says it does. And my rep's pretty honest about which ones won't do what I need.)
At work, if I need to clean out an evap, I use compressed air and brake clean. AZ vehicles tend to have cleaner evaps because of the low humidity.
The BG Frigi-clean is great stuff, use it regularly. HTH. :cheers:
Elaborate on this please, I'm curious. I assume blast it with the aerosol brake cleaner, then blow air on it? Do you do this in the vehicle, or with it removed? The brake cleaner is not corrosive to the aluminum?
Got it cleaned out fairly well. I removed the front clips and two screws on the bottom half of the evaporator box, and that allows you to flex it down enough to spray stuff in there. I used "Purple Power" in a spray bottle from NAPA. It is a heavy duty degreaser and cleaner. After letting the Purple Power sit for a minute or two, I then rinsed it off by spraying it down with warm water from another spray bottle. Repeat cycle until clean. For the really thick stuff in the above pictures, I was able to stick a toothbrush in there and scrape most of it off, then did the spray and rinse again. There was a bunch of pine needles and nastiness in the bottom of that box though. Got it all cleaned out now. Seems to have less smell, will know more over the next few days.
Pretty much got it right there.
The trick is to go easy on the air. My blow gun is very adjustable. Too much pressure and you'll bend the fins over.
The brake clean we use is harmless to aluminum. Carquest brand.
And this is done outside of the vehicle, although it could be done in it. Pull the resistor block and use the straw that comes with the can.
I don't know if brake clean would eat the dampening material inside the evaporator box, though. I used dish soap to clean mine when I replaced my evap.
