Christmas Parts
Utah
Thanks to my new found friends at Cruiser Outfitters, I have a ton of new things to do. Hoping I have it up and running again before spring!
Parts I am hoping I can put in the truck:
- T Case Rebuild Kit
- Drain / Refill plugs
- Oil Pan and gasket
- clutch kit
- oil pump
- valve cover kit
- seal, lots of seals
- ebrake cable
- oil cooler o rings
- u joints
Not purchased yet, but coming soon
- Cat back Exhaust and Y pipe
- Interior carpet
- center console
All advice is welcome, and if i forgot something let me know, Id like to "get it done while Im in there"
- Rear main seal
- Resurface flywheel
Pinion seals front and rear sidnce you're almost at them and you'll be in a seal-pulling mood.
Just googled what a pinion seal was. The two seals on each side of the trans/tansfer case.
I am hoping those are in the rebuild kit and in the picture. If they are not, thank you I will definitely want those. I think they are the ones leaking the most.
No, the seal on your differential: where the drive shaft goes in to the third member.
Be sure to use red locktite on the pinion nuts too: bad juju if those back out.
Ahh.. thank you. I looked at the diagram wrong. Good call, I was not thinking of those, but they are essentially the same seals as the ones I mentioned above just on the other end of the drive shaft.
