Chevy wheels?
Unbelievable. I am wondering the same as someone locally has some 16" Chevy Avalanche wheels with new studded snows for cheap. 6 lug. Fit?
DougM
The 6 on 5.5 pattern is consistant with older Chevy 1/2 ton 4WD trucks. Offset could be an issue, as well as the fact that the center-bore of most GM wheels is too small to clear the larger Toyota hubs.
I have a 2004, Chevy Suburban (6x5.5). I know for a fact that the center bore will not clear the hub. I guess you could machine it and bore it over, but I would be concerned about the resulting integrity of the wheel. I will double check when my wife gets home on Tuesday with the truck and will let you know.
I have a line on a ton of Nissan wheels, 17 and 16 inch in Eugene, not sure if those will fit, never checked but if you want some cheep I can probably arrange it.
Matthew
