Chevy V8 help
Colorado
Just bought a '79 FJ40 w/chevy 350 v8 and stock 4 speed. When I bought it, it had a pretty good engine shake (runs rough) at 2000+ RPM (In every gear). Makes hiway driving not much fun.
First, took off all the belts, no change.
Second, replaced the harmonic balancer, it was bad, the PO must've run it that way for a long time. That helped a little.
Third, tuned, replaced spark plugs, wires, cap and rotor, set timing for a 1976 Chevy Blazer w/350 @ 12 degrees BTDC (6 + 1 degree above sea level approx). That helped a little. Was set a 4 degrees.
Last, tightened up all the motor mounts, no change. :mad:
All of the shaking is in the front of the motor, I don't get alot of shake in the shifter, did a search and there is alot about driveline vibration, which I don't have.
My question is: what else can I try? Replace the distributor? The motor mounts look good but maybe replace? Or is the engine toast? Maybe the PO did some damage to the mains running that bad harmonic balancer? Could I have gotten a bad replacement harmonic balancer? :confused:
Just seeing if anyone else has had this problem. Thanks.
Lots of things. Bad timing chain, burnt valves, bad vacuume leak. Have you checked the compression on all cylinders yet? A real hassle, but necessary when trouble shooting. How about the vacuume? Check that also.
This may be a long shot but could new bushings in the motor mounts help? I hear that the AA motor mounts go flat very quickly. Thus transfering alot of shaking to the cruiser.
Even idle? If the idle is rough too, I'd start with a cylinder balance test.
Does it do it without a load on the engine? Can you make it shake by running it at 2000 in nuetral? If you have a cylinder dropping out under load, that sounds like an ignition problem.
2000 RPM in every gear? That's a weird one. I kinda wonder about the harmonic balancer as well. Where did you get the Blazer info? Is that what the block stamping comes back as? Are you sure it hasn't been stroked with a 400 crank?
I think the block is a '70-'71 2 bolt main w/holly carb, 4BBL, and an HEI dizzy. The engine idles very good and I don't get the shake until approx 2K+ under load or not, does not matter.
Thanks guys, all good suggestions, checked all the plugs wires and no vacuum leaks. I will do a compression test this weekend and have ordered some replacement motor mounts. A mechanic friend pegged the bad harmonic balancer and his other suggestion was to replace the motor mounts.
Just can't see how those could go bad? They are just a hunk of rubber. Keep y'all posted.
What type adapter is mating the engine to the trans?
If it is the old Downey plate via a cast iron GM bellhousing, I would bet it is inside the flywheel clutch area.....ran into a couple that had issues of several different types, wrong Pressure Plate, cracked bell housing, pilot brg missing on one etc......symptoms exactly as you describe.
Butch
UPDATE:
Changed the motor mounts, this is the old style conversion kit with the yoke plate attached to the front of the engine and the stock Toyota motor mounts. Result was mixed, might have taken a little of the shake out of it but I will have to drive it more to tell.
This weekend I will do a compression test on the engine.
Also, I am waiting for some new transfercase cross member mounts from MAF. I will keep you posted.
UPDATE:
Checked the compression on all cylinders:
120, 120, 120, 120, 115, 120, 118(ish), 110
Seems pretty good, motor has approx 90K on it.
I got the new xfer case crossmember mounts from MAF, and...
That was it, after I replaced them, runs and drives smooth (you know as smooth as a 30 year old truck can).
Thanks for all the help!
