This is a question for those here who might have a chevy TBI setup.
I am having an idle problem with the tbi in my Chevy Sub. Its currently my DD intill I get the 40 back on the road. The truck is a 90 with a 454. It had a high idle problem when I took it to the smog police. The tech said that it was either the idle air control valve or the butterfly shaft was worn on the tb. I have replaced both the tb and iac valve. The idle was still to high. I attempted to adjust the idle down using the throttle idle screw. It didn't come down enough. What seems to be the problem is the vacuum module that is connected to the throttle linkage is keeping the butterflies from returning all the way to the stop. The idle comes down when I manually pull the throttle towards the stop. Can the module be adjusted, or does it need to be replaced? Is there another problem that is causing this? Not much experience with tbi. Any help would be much appreciated.
Thanks Brad
I forgot to mention that I did reset the computer.
Thanks Brad
