Welcome.
Call and talk with JIM, the owner of Downey, and he will talk with you about clutches, throw out bearings and anything else you need.
I had a 78-40 in the shop two years ago that the PO had installed a "chevy" clutch in conjunction with a Downey flywheel housing....the clutch fingers were not the correct height and the throw out bearing was not the correct one for the clutch creating all sorts of issues with engagement, etc.
When I talked with Jim then, I was told that they no longer use Centerforce pressure plates and drive discs for the Land Cruiser conversions, and when I used the parts that they sold me, and the pieces that I was told to procure on my own, the set up worked perfectly, and has continued to do so since.
Not telling you what you should do, just letting you know what worked for me.
Good luck!
-Steve
