Chev help needed Urgent
Utah
I am trying to help a friend of mine who is stuck on the side of the road in Beaver, UT. He is in a 1991 5.7L TBI C1500. The truck decided to quit and will not start. He has checked the fuel pump, and injectors which are working fine, he has replaced the coil, cap, rotor, fuse, ignition module, and magnetic pickup, but no spark. The check engine light never came on, so we are assuming there was no code thrown. He has no way to troubleshoot the problem, he only has redneck tools available. If anyone has any ideas please let me know.
Thanks
Scott
Does the damn thing have an ECM / PCM computer/controller? On the way back from Ouray CO last year my Durango decided to just 'die' while we were travelling at about 75 mph...No engine = no power steering, no power brakes, etc. etc. Sounds similar that the D would turn over but not fire up. Had to have the POS towed 100+ miles home!
Good luck to your friend.
Yea, it has an ECM, but I wouldn't think it would just fail would it?
Any other ideas on what to check? I am out of ideas, and it looks like I will be driving to Beaver after I get off work tomorrow.
By saying the magnetic pickup in the distibutor do you mean he peice that screws down and has some wires that plug into it? I had to replace a peice in the my distributor (forgot wht it was called) but I had to dis-assemble it and pull the shaft out of the distributor to replace it.
I had similar symptoms.
Good luck.
Yea, the exact piece you are talking about. The distributor must be pulled to replace, but still no luck.
Regarding the ECM...
Mine did just 'fail'. Drove from Denver to Ouray with ZERO problems...Next morning got up, went out to start the truck and nothing. Thinking WTF...Let it sit for a couple hours thinking about what to do and tried it again and it started right up. Did this off and on where it would be running just fine and then BAM, dead in the water. Finally decided it was prudent since the family was along to just have it towed home and fixed before we got to an area where cell phone coverage was non-existant. The only message I got was a "no bus" message/ Good luck.
Thanks for the info, I think I will go to the salvage yard and grab one as a last resort. Thanks for the help, if anyone else has anything please let me know.
Thanks
Scott
have you checked all the grounds? (including dist. itself) or the leads on the module inside the cap?sounds like your aren't getting a tach signal. You can check the pickup again with an a/c multimeter you should get between .5 and 1.5v fluctuations as you rotate the shaft.You didn't say whether you were getting fuel though? If it is spraying fuel, I'd say check the coil again.
This might help after hours ... from the freeway go to mile marker 112 beaver exit to the Phillips 66 ( IIRC) near the Wendys.. they will give you the phone number to the Napa Dealer. For $10 he will open up after housrs ( anytime) and get you parts if needed.
Let us know how it goes....
can you hear the fuel pump inside the tank?..... even though your say you are getting fuel... I have seen those pumps go bad a number of times. As was said before check the schrader for fuel pressure. I had a frame to engine ground strap corrode so bad I could not start my 89 350 in my cruiser. Always check the grounds.
I had an ECM go bad on a 90 Fullsize Jimmy after 1500 miles...so it does happen but rarely.
The fuel line has been disconnected at the throttle body and there is plenty of fuel pressure to that point. Everything on the dist looks fine, but since I am not down there I am not 100% sure, but the kid wrenching on it is a pretty good mechanic. If I end up going to get the truck I will take my multimeter and start doing some checking. We think there may be a possibility that the temp sensor went bad causing the ECM to shut down the motor. Hopefully this may be the problem.
There is now a new problem. The keys got shut under the hood and the doors are locked, and the closest locksmith is $120.00 away. I now am trying to find a way to get keys to Beaver.
Thanks for all the help
Scott
Just thought I would let everyone know, the problem was the magnetic pickup. It was replaced twice before we got a good one from the parts store, thanks for all the quick help.
Scott
