chev conversion
Yep.
What about it?
is that a chev t-case
it doesnt look like it
i would like to make the conversion from chev to yota on the driveshafts. is that what you have done?
ive bilt up a 83 yota pickup and that is what i did.but im not sure if it works in the fj.
No, I don't think it has ever been done. Pictures lie. Perhaps you could do one and tell us how to do it????? Read, research, read some more, search and read some more again and then some more again and come back to us.
That's a Land Cruiser transfer case (you probably have one VERY similar). Advance Adapters (and probably other companies) makes an adapter.
The problem with using a chevy tansfer case is that then you'd have a centered rear output going to an offset differential. Not a problem on a toy pickup, but on a cruiser, the rear driveshaft tends to end up short and angled anyway so you have to address it. Either a custom (or swapped in) rear axle to center the diff, or use the stock transfer case and pony up the $$ for the adapter.
dgangle said:
No, I don't think it has ever been done. Perhaps you could do one and tell us how to do it????? Read, research, read some more, search and read some more again and then some more again and come back to us.
New guy, TH350 with a V8 in a FJ40 is super old school and has been a lot. I've built one myself this way.
Your not going to have a lot of room for a rear shaft unless you move the engine as far forward as possible. Don't fawk this up or you'll make the truck into something that is afflicted and can't wheel. This is one of the swaps where you need to pay attention to this where as with many other swaps it's not as critical.
The Downey Adapter is a lot shorter than the one sold by AA. I strongly prefer it. Last I checked, Downey was still making it but they are a pain to get info from and sometimes have lapses in their production.
Doing the swap with a Downey adpater requires a custom front drive shaft part which you don't have to do with the AA part but you'll wind up doing it anyway if you wheel unless you want to cut the crap out of your trans oil pan.
Call AA and talk to Vic, get their Land Cruiser swap manual.
Search.
-Stumbaugh
JD68TOYALWAYS said:
I have mine set up 350 / TH400 with a 205 chevy transfercase. I think you will want to upgrade stock axles to Dana 60s.
Not necessary..
You can get a the 350/350. Keep the yota t-case. Longs in the front.
And to answer the original question. Yup
Here is one of my pics
I wish I had Ram Jet on top of my engine :frown:
I have a 383 stroker, 350TH, 1/2 NP203 and the '74 t-case, it has worked great, I did move the rear axle back about 1.25 on the spring perch, the trickiest part was getting the shifter lined up for the NP203. This gives 1:1,2:1 and 4:1, if you want more info e-mail me at crzr74@hotmail.com.
Frank
I Installed A 350 Fi In My 79 40 Useing A Marks Adapter From Advanced Adapter And Kept Toyota T-case And Transfer Case. Did Not Have To Move Anything. Put The Motor In Right Place.
