Check your caliper bolts!!
WARNING: LONG POST
What started up as a casual Saturday driving to Phoenix to sell some sliders to another MUD member turned into a nightmare for my poor 80:frown:
A little background: I retrofitted locking diffs, regeard them to 4.88, installed them, and rebuilt both front and rear axles about 1,500 miles ago. Ever since then the ABS system has been activating during the last 3 or 2 mph of my stopping. I already have the new wiring harness with sensors ordered.
The story: When i exited the interstate coming home from Phoenix and applied the brakes near the red light, the truck made a loud metallic pop and stoped instantly (from about 10mph). I thought one of the diffs grenaded or the transfer case decided 110 degree heat and interstate driving was too much.:rolleyes: The truck would not go foreward at all from that point. I did not force it though. THen I put the baby in reverse and it made a smaller pop then drove. I ended up driving in reverse up the wrong way of the on ramp and pulled into a gas station to play with it a bit. I looked under the truck thinking the front driveshaft u-joints, found nothing. I drove the truck back and forth in reverse and foreward and it only stopped horribly when I applied the brakes going foreward. I ended up driving foreward slowly home using the transmission to brake. When i got home and had to step on the brake, it stopped quicker and worse than before and then my passenger side tire went flat almost instantly:mad:. So, I droped the spare, jacked the front up, pulled the old tire off and found the culprit.. (Pics below)
My Caliper bolt fell off somewhere on the interstate and when i stepped on the brakes moving foreward the force of the foreward rotating roter pulled the caliper up, smashing it against the side of my rim. So, I have a new bolt on the way and rechecked all my other ones. So, I would check your caliper bolts now espically if you have had your calipers off recently.
On a side note, to top it all last night some punks decided they would drive trough my apartment complex and smash out the back windows of the nice cars and trucks. Mine of course was smashed and a few other nicer cars for the area.
Been there, experienced that. Now I torque them to exactly "damb good and tight".
Sorry to hear about the damage and the rear window.
Yeah, I lost one a few months back so I replaced them all at once (and torqued them per ESM) just in case. A few weeks back I lost the same one... well, that fxxxer isn't coming off again without a huge breaker bar :lol:
Seconding the recommendation that people check these :) :cheers:
As a note here are the part numbers:
bolt - 90101-12144
washer - 90201-12452
JP,
I'm glad you're OK.
I've seen happen on the trail. It's no fun.
It would be a good idea to carry a caliper bolt and washer in the toolbox.
Regards
Alvaro
As I just replace my two front calipers I am concerned about this. I torqued the bolts to 90 ftl bs as per the FSM. Should I also maybe put some blue locktite on them? Do you guys torque them to more than the 90 ft lbs?
MSGGrunt, I torqued these to 90 ftlbs. However, i think my problem with the ABS coming on intermentely may have worked the bolt free a bit. Just a thought.
You torqued them to spec and they still came loose? Wow, thats a scary thought.
Yeah, similar here too. Heard a slight ticking noise with the windows down when driving by other cars. Thought it was the birfields. Noise slowly got louder and louder, pulled the wheel off finally and the caliper bolt had backed out enough to touch the inside of the rim!! My buddy in WV did a front brake job before I bought it, I of course tightened them all down after that. Check your caliper bolts!!
See it all the time with wheel bolts, caliper bolts and axle bolts. Torquing a bolt to spec is only good for 1 time on a heat cycled component like a brake caliper bolt. I would consider using new bolts with a mild loctite on them. Or, antisieze works well too on a new bolt, but you need to back off the torque spec ~20% IIRC (this is prematex's silver common spec, look up the spec for the A-S you are using), since it's now considered a 'wet torque' spec.
As a rule, I prefer loctite flavors to A-S because you are really looking for the anti-weathering/galling properties inherent to sealing a bolt. That doesn't require antisieze, and many fasteners create a bigger problem using A-S. Loctite gives the same 'anti-sieze' properties without the propensity to back out.
I read an interesting series of articles in a shop rag about the debate on retorquing wheel bolts after 100miles of re-installing a used wheel bolt. A bit of a logistics problem, so I tend to educate folks on using a torque wrench, and reusing it after a wheel install.
Here on the brake caliper bolt, you have massively heat cycled bolts that should be considered 1 time use stretch bolts. As such, once stretched, if you retorque to the same spec, you actually reduce the tensile strength of the fastener = failure of the fastener, or lost fastener, or worse.
Glad this one didn't cause a catastrophic loss, and one of the reasons caliper bolts tend to be interference fits.
My .02
Scott Justusson
Ken,
A little locktight might do the trick too.
Alvaro
I don't torque my bolts I just armstrong them in place.
The thing about torquing a bolt is that the threads are assumed clean and free of debris. Anything in those threads such as dirt, old loctite or dried antiseize compound will throw off the reading and you will end up under spec.
You should also make sure any rust or dirt is cleaned away from the head of the bolt and the contact surface on the bracket so that you get a good contact between the two.
x2 -> Same here also ;)
Sorry to resurrect an old thread but I felt that there are some good points in here that are often overlooked. Especially the part about not reusing a pair of ~$3 fasteners and risking everyones safety.
I put in 100 series pads at the beginning of this summer and cranked the bolts down, then reefed on them again when I rotated tires about 200 miles later. I stopped in front of my house today around noon and veered(sp) right hard. pulled the wheel and it looks exactly like the one at the top of the thread. The lower bolt was missing.
I live in the middle of nowhere and had to "improvise" (scary huh) I stole one from my '82 mini-truck and it worked till I got a new one.
Lesson learned.
Bolts require an amount of "stretch" in them to retain the clamping force. If the bolts have stretched then torquing them to the std spec is not going to help.
The specified torque given for a bolt is to allow for this. To much is as bad and to little.
Best check the bolts or replace them. Do them up to spec, drive and then re-torque.
Well, yesterday this happened to my LX.
My wife and I were at sonic, and we backup up to leave and head a mild grinding and then a pop. Wasn't sure what it was, and it didn't sound severe, so we starting driving. No more noise. We pulled out into traffic to make the u-turn and we heard another faint grind, but nothing bad.
I pulled into a nearby Kroger's and started looking under the car. I could see nothing out of place or odd.
I had Amy get in the driver's seat and I looked at the front axle, driveshaft, etc to see if I could find this weird noise. Nothing looked out of place. I could see the driver's side tire bind up in reverse, but not forward, but still could not see why. My thoughts were accelerating to the worse, such as my hub had come loose and now I have munched the spindle bearing races and all. Then I notices a shiny piece of metal fall from behind the DS front rim. i picked it up - it was a think sliver of what felt like aluminum.
I jacked up the truck and took off the DS tire. I had a silver line etched into the back of the rim (very faint). I looked around and saw the caliper was not seated, and then discovered the bolt was out of the top caliper mounting bracket hole. The bolt was still in the bracket hole, held in place by the rubber brake line.
I didn't have any "real" tools on me, so I tightened it up by hand and then did the best I could with my leatherman to button it down as much as possible. We drove to the nearest auto parts shop and I picked up a 17mm socket and ratchet and tightened them correctly.
The funny thing is this: I have never changed these brakes. the PO hadn't either. I was running on an OEM Toyota caliper installation, and this came loose after 86k miles and no warning. My PS caliper bolts were loose too, but not nearly as much as the DS.
Check your bolts!
