Check my logic
Albuquerque, NM
So for the past week or so, my oil pressure has been kinda weird, it goes up to a normal spot and then it drops down a little. It stays down for about 10-15 seconds and then pops back up to a normal range! It never drops below 1/4 and always returns to normal. Oil level is good, about 1500 miles since the last change. Truck has 218k on it.
So after searching for a while, i've come to the conclusion that my oil pressure relief valve is probably going bad. Going to replace it this weekend and see what happens.
Does this sound correct?
Thanks
Daisy
I'd remove the sending unit completely and clean it out just in case something is lodged inside of it. Also, if you can swap it with a buddy and do a quick test (try to duplicate the same problem) just to rule it out is worth the time and effort.
The oil pressure relief valve is a very simple component and not prone to failure. Basically it is just a spring. As others have said, it is much more likely to be an electrical issue.
-B-
