Check Engine Light
I have a 97 land cruiser
I removed the Catalytic Converter and the Oxygen Sensor sets off the Engine Light. What can I do??
Run a dummy O2 sensor, or put a cat back in.
Why would you eliminate the cat? You see no performance benefit by doing so.
What Ebag333 said.
I cannot find a dummy O2 sensor, Do you know of any? there was an increase in low end performance.
I disconnect the battery and it resets the computer for a few hours then the light comes back on.
Well then take out the bulb ;P
all kidding aside. You need to "fool" your sensors/ecu into thinking they are happy. They are looking for numbers you aren't getting them.
The only increase in performance you'll get is if you put on a bigger and more free flowing exhaust for the whole length. There are lots of restrictions in the OEM exhaust, and just eliminating the cats will not eliminate those restrictions.
Additionally the OEM cats are actually quite free flowing as is.
Here's a before and after dyno of a (blown) 80 with OEM then a 2.5" free flowing exhaust.
As you can see, not a huge difference. And that's with a significantly larger and far more free flowing exhaust. So that's why just eliminating the cats won't do much for you, they aren't a significant restriction.
Regarding dummy O2 sensors, there's nothing off the shelf that's plug and play. You'll need to splice it in or make your own harness. I'd recommend getting an adjustable one as the hard wired ones may or may not work. Adjustable ones you can play with to tune it in and make the ECU happy.
Had similar problem with O2 sensors a few years ago. Could not get them so engine light would go away. Tried changing out the new sensors. No joy. Took out the check engine light and no worries. Not sure what good it really does, can tell more by the way the engine is running.
