Check Engine light...saga continues....
Well, you could always remove the bulb, or put electrical tape over that spot on the dash.....
83,84,85 codes are transmission codes. The tcm and the ecm are not communicating correctly, The reason they dont clear from the efi fuse is that they are "hard codes." That means there is something wrong with just key on. I would bet you have some broken wires somewhere. I think Im wrong but I think I recall fixing them by the egr valve. 28 is the only o2 code you have. I would check the harness going down the bell housing. I have replace a tcm to fix these codes also.
This may or may not help much, I was having a code 26 from time to time, I replaced the o2's within the last 6 months...yada yada yada
It came down to a loose neg. batt. connection.
Good luck, This crap can get the better of you
