Sorry the code in the title is wrong. The code is P0136
Hi Guys,
I purchased my beautiful 97 locked Cruser several months ago with the check engine light on. Code was P0136 or O2 sensor after the CAT. I figured this would be an easy fix but have been proven wrong. Below is a list of everything I've done but the same code just keeps coming back. Any help / advise is greatly appreciated.
1) Replaced front and rear O2 sensors several times. Started with Denso but am currently using Toyota factory sensors. The light came back...
2) Replaced exhaust from y-pipe to muffler including new aftermarket CAT and Magniflow muffler. The light came back
3) Took to Toyota dealership (at $130 per hour) and had all electical between ECU and O2 sensors tested for short or bad connectors. They said my O2 sensors are fully functional and working within Toyota specs. Said the truck would pass any sniffer test and the issue must be a bad ECU. ($1,800 for a new one) Light still on...
4) Purchased and installed a used ECU out of a parted out 97 LX450. (Part numbers match 89661-60650). And the light came back on...
I really don't know what else to do and the dealership said they are stumped. What else should I try?
Hi Guys,
