Check engine light---Error code 32.
Here....mostly.
I went and turned my truck on and noticed that the reading for the air flow voltage on my little meter was reading 0v. I thought hmm that's odd, but if I tried to give it any gas, you could see the truck start to go lean. So I turned it off and started it again because I thought it might just be the "special" computer I have in my truck, and the same thing, this time the Check Engine light came on. I used the paper-clip method, and got a 32. Any thoughts? Thanks a million.
A 32 is "Volume Air Flow Meter Signal". "Diagnosis" is "Open circuit in E2 or short circuit between VC and VS".
Trouble areas:
VAF meter circuit
VAF meter
ECM
Maybe yer snazzy computer is toast :-\
[quote author=cruiserdan link=board=2;threadid=7022;start=msg57991#msg57991 date=1067747247]
Trouble areas:
VAF meter circuit
VAF meter
ECM
[/quote]
So what exactly is E2, VC, or VS? Are they wires off the ECU? Any ones in particular? Any pics from the FSM? When I pulled the glove box out I could see where the splicing was done, Maybe there's a short there now. Thanks Dan.
Very possible. When I was troubleshooting the AFM in my '93, I pulled the computer out and ran some splice wires from the computer to the connector on the AFM to find the open. You can fit a paperclip in the back of the computer connectors.
The factory manual covers troubleshooting the computer and wiring in detail.
Cruiserman,
Thanks for the word, can you elaborate online a bit more, or send me a PM. The FSM is still in transit. C-dan was out when I placed it on back order. Thanks.
FIXED IT!!!!
A programming error in my fancy little computer. :D ...err should I say a programmer error. :slap: :doh:
It's too late to cancel the "book"...... :flipoff2:
Really glad to hear it's OK..... :cheers:
D-
Still want the book...I have a strange feeling I'm going to need it more than just once! :doh:
