Check engine light and some odd behavior
Delawhere?
About 2 hours into our 2 1/2 hour trip to this year's family vacation, I got a check engine light. I don't have access to a code reader, so I don't know what code it has thrown.
The CEL has been on a couple of days, but I'm not having any issues with rough idle or mis-firing.
Only strange behavior I've noticed is that the security system has decided to reprogram itself so the audible chirp sounds whenever I lock or unlock the vehicle. Only reason this is odd is because I didn't do anything to change the programming from silent arm / disarm.
My biggest concern is that I have an alternator going bad, and I could get let down from running without enough charge.
Of course, now I'm wishing I had a ScanGage since I'd know the CEL codes and the voltage output from the alternator. Gotta do check to see if they will overnight a ScanGauge to me. ;)
Any thoughts or insight is appreciated.
-KK
Get the code pulled. Any parts store should do it for free. Otherwise stop in at a local Wally world, buy one, use it, return it.
Your alarm might "reprogram itself" if it's lost power and reset. Only thing I can think of that would do it...
Probably an 02 sensor. Just a guess but that's what I found when it ran fine but had the CEL on after driving for a while. Not really a concern the ALT. is more of a problem. If it quits charging smack it with a hammer. That got me home last time mine was going out.
In my area, this has gone by the wayside :mad: Neither Autozone nor Checkers offer the free CEL code pulling any longer. This might be a nation wide trend, I dunno.
Pulling the code will give your best answer obliviously. In the 2 separate times mine has thrown a CEL it was first the O2 sensors, and 2nd the EGR modulator. We could speculate for days.... so find a shop/parts store that will pull it for ya or just buy one with a good return policy ;)
Maybe a local mudder in the area could lend a hand with one.
Seems most the CEL's are a indication you have malfunction but wont kill your truck.
Point taken; ScanGauge ordered. :)
-KK
Cool. Did you ever find what code you were throwing? or waiting for the new toy to tell ;)
Since I'm on vacation, I didn't spend the time to track down a code reader. $10 off retail price and $4.99 for overnight shipping from amazon (via amazon prime) seemed the best way forward. I've been putting off purchasing a ScanGauge for a couple of years, so now seemed like an easy time to make the decision to purchase.
I'll post what I find later this week.
-KK
My new ScanGauge shows PO420. After about 20 minutes of reading on mud, looks like I have some O2 sensor tests to do. And while I'm testing the O2 sensors, I'll check for leaks. With 129K on the LX, I'm not ready to jump to a "replace the cats" solution.
This post from cdan was the most concise summary of the issue:
DTC code P0420:
"The ECM compares the waveform of the oxygen sensor located before the catalyst with the waveform of the oxygen sensor located after the catalyst to determine whether or not catalyst performance has deteriorated."
Trouble area:
Three way catalytic converter
Open or short in heated oxygen sensor circuit
Heated oxygen sensor
Repair sequence:
Check sensor 1, bad...replace. ok....check sensor 2, bad....replace. ok.......replace three way catalytic converter....
Regards....Dan :beer:
"Heated O2 Sensor" looks interesting since the truck was run for 2 hours on a hot summer day when the code was thrown.
I reset the CEL, and I'll monitor on the 2 1/2 ride home from vacation this weekend.
Now I'm off to read ScanGuage posts to see where others have mounted it. :)
-KK
KK, did you ever find out that it is?
I have got a P0420 this morning (on my 96 LX with 93K miles on the clock). Reset it with the ScanGauge, it has yet come back. ( It is not my DD. Last time I drove it was a week ago. Not sure the code has anything to do with infrequent usage).
Short story: No, not yet. It's still on the to do list.
Long story: Checked the FSM to find the O2 specs for test. In an effort to locate a VOM to read the resistance of the O2 sensors, I found that my VOM was shot. Then upon friendly inquiry, I found that my neighbors was shot. Now I'm asking Santa for a new Fluke this year. :)
Back story: This CEL code has only turned on twice in two years. It was the same trip, near the same location, only in a different year. Due to the low occurrence rate, and due to low availability for my time in the garage, the O2 test has been out prioritized by other routine maintenance.
-KK
Before replacing O2 sensors (and especially the cat$), check the entire exhaust system between both O2 sensors for leaks, including the O2 sensor gaskets. I had a P0420 and I solved it by replacing the gasket between the cats and one after the second cat. If you have a leak between the 02s, the second O2 will not get the reading it is looking for and it can throw a code. It's the easiest and cheapest place to start!
Adam, thanks for the tip.
-KK
Mine has done the same stumble /low idle trick twice.
First time was after I got it back from the brake shop where they had obviously disconnected the battery.
Second was last weekend when i ran the battery down and had to jump it off.
Both times the problem corrected itself within a day or so.
Figured it have something to do with my egr cel and the computer needed time to recalibrate itself
I guess the heat expand filled up what ever was leaking. After resetting the code, I was driving mine the whole afternoon yesterday and got no code at all. I am thinking about the gasket between the two cats too. The connection between the two cats on my truck looks quite nasty so much so that I am afraid they will be breaking apart if I start cutting/hammering/drilling (don't know how else I am get them off).
The bolts are a disposable part here IMO. I have used an oxy-acetylene torch to heat them up and then wrench them off and I have also used a regular grinder with a cutting disc to remove the head or nut from the bolt. I prefer the grinder method. With the second cat removed you can cleanup the gasket mating surfaces with a wire wheel before putting it back together.
I was able to find my leak by starting the truck and having someone with a welding glove block/restrict the flow at the tailpipe. This exaggerated the leak and made it pretty easy to find. Using a feather on a calm day might also work
:cheers:
Reporting back because of a related incident.
I was on the way to work when I heard a really loud exhaust leak cut loose.
Turns out it was my upstream O2 sensor. When I got to my mechanic, all that was left were two semi-rusty studs, part of a rusty O2 gasket, and a dangling O2 sensor.
An hour later, I was back on the road with a new O2 gasket, new nuts and lock washers. My mechanic chased the threads of the studs (8Mx1.25) with a die to clean them up a bit. It's interesting that the nuts would be rusted enough to fall off, but not adversely affect the studs to the point that they were unusable. It's conceivable that the nuts could have backed off, but I doubt it.
I don't know if this was the root of my CEL issue or not, but I'm glad to have this one behind me now.
-KK
