Chebby 305
Fuel in carb doesn't matter because the throttle doesn't do anything different when the key switch is in either run or off, it just stays in the idle position.
I suspect timing issues.
Have you read this thread?
https://forum.ih8mud.com/showthread.php?t=105423
mdjohnsen said:
i just thought it was funny when the 305 sputtered an died
my camaro used to do that when the idle was set to high. doesn't anymore. got a new carby
it has a 305
haha see my fj does that two in reverse mode. WHen i start it up and it dies in the morning because of the cold...1 second later it starts itself up again and idles fine. I think its funny
Sometimes in older engines the carbon bulid up on the piston heads is thick enough and remains red hot to act as a "spark" for a couple of revolutions causing the engine to sputter after the ignition is off. I would assume the problem would be worse with a mechanical fuel pump rather than an electric one
