Engine wont quit running
Madison, NC
I just bought my first fj40 a couple of weeks ago so all of this is pretty new to me but it seems to run fine except a little bit of stalling out when you first give it the gas then it smooths out and runs like a champ, it idles good (maybe a tad to fast). then when you go to turn it off it keeps running for maybe 5 to 10 seconds, not a smooth running but a spitting and sputtering running. other than that it seems to run fine i have driven it all over the place since i got it and tackled several problems in the past couple of weeks with everybodys help. thought i would see if anybody had any experience with this such of thing. Thanks Again for everybodys help, if not i would be up the well known creek without a paddle.
Its a 79 2f engine it has a chevy carb on it im not sure why, it came on it when i got it. it has the original air filter and it looks like everything else is original. Thanks
not to hi-jack but i have seen this problem starting on my fj40 ... is the timing to advanced or retarded? I have no fule cut off so i know thats not it
I had the same issue. Swapped out to a different carb and solved the issue completely (didn't want to rebuild the junk one that was on there). Seems to be much more reliable now.
Also improved starting & idle a ton.
See about getting a stock carb in light of the engine being a 2F. SOR sells the "non-USA" carb, which I have on my '77 cruiser. I haven't been at all disappointed with it.
Good luck!
Do you have an electric fan by chance?
This is wierd but the way I have my fan wired right now causes the engine to run about 3-4 seconds after I turn it off. If I unplug the fan completely it does not do this. It must be somehow sending current back to the dist as it coasts down. I really don't understand it, but hey.
Just a thought.
But from how you describe the rest of it's running condition I'm leaning more towards a timing issue like the others said.
I dont think it is a holley, maybe a rochester? and i dont have a electric fan although i wish i did. it only continues to run if i shut it down after it reaches operating tempature. if i shut it down after running only a few minutes it doesnt do it. thanks for the replys.
