Cheapo tire carrier solution...PICS
Rixeyville, VA
First things first, this isnt some grand invention and its really nothing that awesome but for those looking for a half we decent way to secure you spare and hold it, this will suffice.
I've been running my 80 like this for about a month or two, it seems to work pretty well and has kept my spare from flying all over the cargo area until i can get a new rear bumper w/ tire carrier.
The pics pretty much tell the story but what i've done it place the spare directly over one of the two rear, 3rd rear seat hooks. To secure the tire i used a yakima tire carrier bracket that was originally used with my yakima load warrior. I took the tire off the roof b/c it made the truck top heavy, was loud, and hurt my mpg a little.
All, i pretty much did was flip the spare upside down and use the yakima hook with the hook on the floor. The spare is not very secure and actually locked into place. As i already said, its nothing great but still another option and cost my about 50 bucks.
This final picture shows everything in place. The sub is bungy'd in place, the small tool bag also bungy'd using the 3rd row seat hook and one of the small 4 oem hooks. With the spare flipped over and all secured in it also serves as a good "bowl" to keep stuff in.
that is an excellent idea, much better than ratchet straps etc...!
I'm gonna build me one! with a hook and then a 2x4 across the tire or something like that.
just a wild random thought
is there any way to incorporate some sort of a bead breaker design into the tire hold-down?
or do you think that that might be pulling a bit too hard on the 3rd row seat mount & its quicker to just use the bottle jack under the bumper trick so why bother?
reffug said:
Nice Brandon - now go do some studying.
I kinda liked the tire on top Heep look.
Thanks, i did prefer the look of the of tire on the roof as well but it serious hurt my gas mileage by about 1-1.5 mpg....considering i dont have a job anymore and with the current gas prices, im gonna do all i can do save a little. I'm even thinking about taking the yakima off to cut down on wind resistance...
And as for the studying, your probably right
well, I went out and put mine in. Didn't quite work as easily as I thought.
For one thing, I don't have the middle seats in, only the rear ones and I wanted to keep these operational.
Also, I run 33", dang these things are huge. I could never center the tire directly over a holddown, was always off to the side.
Finally put it up front where the middle seats were, on one side so I still have the rear seats usable for the kids, one more than the other..
Just used a eyebolt going through one lug hole, with big washers and a nut, all of $2 worth. Seems pretty secure. I can also easily put a strap or 2 to help secure it some more but does not look necessary. Without the straps it looks very clean.
Great idea!
thanks
E,
you bring up a good point....right now im just running a stock sized spare, thats probably why it fit with no problems. Also, your right about not having the straps, its nice to have everything very clean looking.
Thinking out loud....The plate on the oem spare tire mechanism might work well for this since it has that little tab that goes into one of the lug holes. You could remove the center of the plate where the chain attaches and run the eye bolt through it. That lug hole tab might help secure it a bit more. Not sure I would want to ruin mine doing this but I'm sure there are some used ones out there somewhere.
Someone used to sell a nice interior spare mount that attached to the 3rd row bracket and mounted the tire vertical. I remember seeing one on the man-a-fre website garage sale section for 10 bucks. For 2 years I've kicked myself for not buying it. According to MAF the manufacturer has since gone out of business.
Jason,
I've heard about that mount and remeber seeing it on man-a-fre's site a long time ago. Its a pretty good idea and i would definately do it over my current setup but as you said its no longer available and correct me if im wrong but i though i recall reading from someone that it wasnt the best quality or it just didnt work too well...i dont remember.
no doubt, a vertical mount would be more space effective. On the other hand, would have to be very strong to hold a big tire securely.
I was thinking about using a turbuckle to secure my tire flat, but decided it was nto strong enough (Al alloy) and went with the eyebolt instead, a 3/8" steel one.
Does anyone have a picture of that tire mount sold on MAF or one like it? I think I may have found one from a board member, but not sure what it looks like exactly or the quality
slee sells them you can see it at their website in the interior products section. I would make my own looks kinda simple.;p
I've seen slee's and its nice, but this other one uses the 3rd row seat mounts. And I've come across one for $50. He just doesn't have any pics of it at the moment and I can't find any mounted pics of it.
