Chasing current leak
Santa Rosa, CA
I'm posting this as a step by step for anyone facing the same trouble. My 40 has had a vexing current leak for a long time. I'd tried to find it with my $20 auto parts store voltmeter, and it was not up to the task. So, I bought a $35 voltmeter off Amazon capable of reading milliamps, and I did as the YouTube video said and disconnected the ground side of the battery and placed the voltmeter in line between the ground cable and the negative terminal on the battery. And low and behold, with the right equipment, I have a 60 milliamp parasitic draw. Not huge, but enough to kill a battery in a rig that can sit for weeks at a time.
So, I went in the cab and turned off the digital voltmeter I have in there (which is usually off, but I had it on for educational purposes), and the draw dropped to 44. Progress, but still not enough.
And then I decided to disconnect the scan gauge, which is always connected. I use it to track what's going on in the 6.0 V8, in parallel with the gauges I have. And there's the real culprit.
Down to 20 milliamps. within the range us sustainable. But, I then disconnected the other outlets in the Tuffy, that are always on.
And that took me down to 11 milliamps.
So, the computer for the V8 is only drawing 11 milliamps. That's great.
I'm going to make the tuffy outlets switchable and leave them off, I never use them. And I'm going to leave the scan gauge disconnected unless I really need it. And hopefully my days of dead batteries are over. But, I'm going to try to remember to disconnect the Bussman I used in place of a fuseable link when I park the rig.
Good job. Same Astro mulltimeter I bought for working on 70s Kenwood stereo receivers - made good use of it also for tracking down the short in my horn circuit.
