Technically it's the solid white wire that supplies system power from the battery. Here is the path it takes...
Main system power starts with the battery + terminal. A replaceable fusible link is attached to the + battery terminal. The other end of the fusible link goes to the 10ga white wire coming out of the harness near the battery. This white wire then goes through the harness to the + terminal of the gauge cluster Amp Meter. Power then flows through the Amp Meter to the - terminal of the Amp Meter. (Note: If the Amp meter is fried the whole system has no power) A 10ga White/Blue wire connects to the - side of the Amp Meter and runs all the way to the Key Switch AM terminal. The alternator B+ wire (also 10ga White/Blue) is spliced into this wire.
So when not running the battery is supplying power to the key switch White/Blue wire which is always hot. This powers the half of the fuse panel that is always on. When the key is on the Black/Yellow wire is tied to the White/Blue wire and powers the other half of the fuse panel.
When running, the alternator is supplying charging current through the White/Blue wire, through the Amp Meter out the White wire to the battery + terminal.
What is your actual question/problem?
