Charging Gremlin
New Mexico.....close to Colorado as I can
Ok not a noob so first I did searching and seeing no one is having any similar issues. Here's the problem....about a year and a half ago I was driving down the road and a bunch of lights kicked on and cruise wouldn't work. Upon research here I saw people having this issue when the alternator went out. Well I load tested it and bench tested it and it passed both with almost 15 volts output. Well crap. Going with mud members I replaced with and O'Reillys alternator and problem solved. Lights went away and charged just fine. Fast forward to 4 months ago and I'm driving home and the 1994 80 dies. Jumped it and got it home. Got up next morning and drove to work without issue. Tested the alternator and not even 12 volts. Well that didn't last but whatever. I replaced it as it had warranty and all good again. Not even a month went by and I noticed my gauge sitting above the 12V mark. I test and sure enough it's it's at 12.97-13.15 @ idle but will raise to 14.5ish when driving. I do a voltage drop test and nothings wrong there. Well heard others saying that fusible link might be the cause so I tested and no resistance at all but I've seen fuses have high resistance and not blow and cause issues. So no biggie only $10 at the local dealer and figured I'd try it. So grabbed it and replaced....no avail. Well few more test and seams like it's the regulator I'm the alternator. Take it back and get it warrantied and replace. All is well. It's been 3 weeks and is starting to drop low voltage. Thing is the voltage is only low when at idle. Any helpful tips, ideas, tests or anything? I am almost certain it's the crappy O'Reilly alternator but until I can finish getting the supplies for the 150 amp alternator upgrade I need this to last and not kill my battery. Thanks ahead of time guys/gals!
This topic has been discussed many times. When you install a generic alternator or starter, you get very good at swapping them out.
Pick up an OEM re-manufactured unit or install the Sequoia option.
Do you have any aftermarket add-ons that could be causing drain? I went through 2 alternators until the third, winch would be the trouble spot. Install isolator switch on winch positive and problem solved.
I have a 52 in light bar, 4 led pods, inverter, underhood light, flashlight charger and couple others but they are hooked into my dual battery setup through a fuse box. I think I forgot to mention it doesn't do it every time I idle. Sometimes I idle and it's 14.5ish volts. Sometimes it's 12-13V.
I hear you, my winch was intermittent, it took me a while to find it. Guys at Autozone helped me find it when testing the alternator in the truck. They do that as well as the bench test. And I liked the lifetime warranty on it.
