Charcoal Canister
Santa Fe, New Mexico
Is it okay to hook up the vapor canister to the pcv nipple without the VSV?
How do fellow mudders set up their vapor can with engine swaps?
I'd like to do away with the VSV on my '75, but I want to be confident that I'm not creating issues either.
The canister should have a passive draw for the vapor. A line to the air cleaner, placed inboard of the air filter element should be sufficient.
I definitely would NOT use a PCV line for a vacuum source, as that will only draw fuel vapor into the oil, which is the opposite of what you want to happen; the crankcase already gets unwanted fuel from engine blow you.
Above, are a couple of PCV connections from a couple of '75 manifolds. The small connection is hose #3 illustrated slightly behind and to the right of the EGR valve, if I am correct, see below.
This diagram (below) suggests a relationship between the vapor canister purge and the photographed part (above).
How much of the above diagram would be best for running the stock charcoal canister? What do people usually do when running domestic motors, do they have an equivalent canister-barb which restricts the manifold vacuum (and maybe sparks from the intake as well) like the one that comes with a factory 2F manifold (photograph)? Does a GM canister work differently from a Land Cruiser canister?
