changing speedometer cable
After looking at the speedometer cable on my 76 fj40 it diffently needs to be changed. I would like to change it out myself but considering that i am not that mechanically knowledgeable, is this a task that i should try to attempt myself and if so could someone take the time to give some direction. I would appreciate and so would my wallet.:D
I just changed mine and it is really easy, even tho i had some trouble trying to unscrew the sleeve on the transfer case, i ended up having to pull the thing out of the transfer case, get it into a vice to get the sleeve unscrewed. So when i pull the spindle out of the TC obviously oil leaked out, just quickly put a towel in the hole so that you oil don't leak out during you unscrew the speedo cable. Not even sure why it was leaking out, seemed to me the fill plug was lower then where the speedo cable plugs in. But you need to do that if you cannot unscrew the cable end
Then when you'll attach the other end in the back of the cluster, just be carefull that the rotating cable/wire is aligned when you plug it into the cluster so that you don't bend the wire, if you do bend it, then it is a pain to plug it. But its easy. I had to remove the skid plate since i couldn't get the end of the cable sleeve unscrewed.
Note that i did that on a BJ42, not sure if FJ have different TC, speedo cable installation.
Easy. Only hard part is getting your hand behind your gauge panel. It either snaps on or screws on back there...can't quite remember. I do remember the scraped up hand though.
PS I used one out of a fj55 or 60 (can' t remember sorry) that was longer cause my non-stock drivetrain made the stock one too short.
I don't have that problem anymore since none of the drivetrain is cruiser:D
one banana job.
BUT
RULE NUMBER ONE!!!!!!!!!!!!!!..............DISCONNECT THE BATTERY. If you accidentally touch one of the ammeter wires or terminals to ANYTHING while you're fussing with the instrument cluster, it could be the 4th of July or worse.:eek:
With the battery disconnect, all is good.
Best
Mark A.
oooooooh....i never thought to disconnect the battery when i did mine....but yea its dead easy, hardest part was finding a speedo cable. my cable snapped in on my 74 im not sure if yours would do the same, i think so though. on the t-case i had to put a set of vice grips on that end of the cable to un screw it but this is defanitly 1 bananna
