changing number 6 spark plug
Boone, nc
Gettin ready to do plugs and wires on my 97 and have heard a lot of talk about the number 6 plug bein a bitch. However, after searching through faq and doin about an hour of other searches i havent found anything that explains how to do this job. Haven't really found anything that makes me think its gonna be that hard for that matter.
Any one want to post up some advice, i've never done plugs on a 93-97. Or is there a link i'm missing?
Never thought it was that hard:
Gently pull the heater hose loop away from the firewall
Put socket and extension down the hole and remove plug
Install new plug and let go of the heater hose loop
Done
Of course, this is assuming you have already removed the intake hose and plastic covers on the valve cover, and pulled the ignition wires.
I taped my plug puller socket to the 10" extension I used to make sure I didn't lose the socket. The 6 is a pain because you really have to get up in the engine compartment and space is limited at the back of the engine. Other than a bit of contorting, nothing is really that hard about pulling plug 6.
I second taping the socket to the extension. Losing that socket in the plug hole on hole #6 is a bad thing. Because of the angle created by the heater hose, you can get the socket stuck on the sparkplug tighter than the extension fits in the socket.
I used a 3" then an 8" together to get it out of my 3FE.
Add this to your list of handy 'Cruiser tools. It keeps you from playing "go fish" when installing plugs because it is nearly a foot long:
Ok cool. That explains why i couldnt find any reason for the job to be hard, it isnt. I wonder why some people have so much trouble with this? Some people say that it has taken them hours to get the job done.
I have an extension that has a lock to keep the socket attacked. Very useful for jobs like this.
The really clever rabbit just uses the spark plug wrench Mr Toyota gave you in your tool pouch in the rear quarter. Perfect length, perfect fit, always there - but often forgotten.
Sure, I'll jump in here
I did mine with the 12" extension mentioned here, but then IIRC, I used a 3/8" "universal joint" which some people call a "wobbly" between the spark plug socket and the extension. Piece o' cake. There's nothin like the right tool for the job.;)
