changing drums to disks
Northern Maryland
Any reason why I shouldn't just switch the entire axle with disks from a 78 to replace my drums on my 69. Seems like it would be easier and would save time. Any mods that I am not thinkin of that would make it just as dirty as just replacing the drums?
Craig
Hello,
I installed FJ60 discs from a 1984 model, along with the mastercylinder and booster, with the proportioning valve. The install was quick and dirty, the only fab work was to the axle housing, the FJ 40 firewall where the booster bolts up and shortening the FJ 60 tierods about 2". The tie rod end from the FJ 40 RH tierod will thread right into the FJ 60 relay tierod The booster actuation rod needs to be shortened 1/2". The axle needed .070 ground off of the lower surface so the FJ 60 birfields will fit into the housing, I used a diegrinder, but a file could be used with a little more effort involved, file until the birfield fits. The firewall needs to be trimmed about 1/4" of an inch on the top of the hole(use the FJ 60 heatshield as a template). This mod has been the most unbelievable I have done to any vehicle I own, I have 33" BFG's on the cruiser and can lock them at will, without much effort at all, it seemes that the FJ 60 wagon has a GVWR quite a bit greater than the '40, so the effectiveness of the brakes are magnified. This mod took less than 10 hours, including runs to the autosupply. I used the original brake lines and hardware. This mod is quicker than an axle swap w/ gear swap, I also was able to get rid of the warn aluminum locking hubs.
I got all the parts from a guy who was parting out the FJ 60, for $75.00. I needed to replace the knuckle upper bearings, but that was poor maintence by the previous owner.
eric
