Hey guys "Dirty Mike and I broke down. He blew a water pump on my way to Vancouver so no I'm stranded 2 hours from home. I was wondering how easy it would be for me to change a water pump and how long it would take. I had a 81 yota pick up and did a motor swap on him so I am OK with mechanical things. Keep in mind I will have to buy all the tools I need.
Yeah...that's why it's never a good idea to hang out with guys named "Dirty Mike" or "Randy Johnson"...
Is this for a 60 or 62?
I'm with Crick...it's a doable job.
For 60:
To remove the Alternator/PS pump belt, you are going to have to loosen up the alternator. Underneath the alternator is a pivot bolt that goes through the alternator itself and the bracket that holds the alternator - 14mm - You'll need two combo wrenches (or any combination of 2 wrenches/ratchets)
The long bolt on the top of the alternator that holds tension on the belt - 12mm. First you have to loosen the bolt that holds the tensioner bracket to the top of the alternator, then back out that long tensioner belt.
Then the alternator should rotate and allow you to remove the belt.
Same on the Air Pump, but not sure of the size of the pivot bolt at the bottom of the pump, but it is a little tricky to get to because will have to push the belt a little out of the way with the socket you are using to get the socket on the head of that bolt. A smaller 3/8" drive extension on the socket helps.
You should be able to remove the fan/fan clutch without removing the fan shroud. 4 nuts, you'll need a combo wrench- 12mm.
Then the water pump is held to the engine block with 5 maybe 6 bolts - 14mm.
3 hoses, so probably gonna need a screw driver there, depending on what type of hose clamps are on it.
You'll have to remove the 4 studs on the old water pump if you don't have 4 new studs. Take two of your nuts (yeah, I see the joke there...) and screw them onto one stud, one on top of the other, then back the bottom one out against the top one (you'll need two combo wrenches to do this) so that the stud backs out.
Razor blade and a rag to wipe the face of the engine block where the pump mates.
You'll need a gasket w/ gasket maker ("The Right Stuff" is good if available). I guess if this is emergency, you could use gasket maker without a gasket, but then you'll have to redo the job as soon as you get home...making a gasket from gasket paper would be better than no gasket.
Don't forget to burp the system to purge it of air after you at the coolant and are ready to start the car for the first time. (search 'burp' for steps in this procedure if you aren't familiar with the process).
Good luck.
EDIT: I just checked my rig and am pretty sure the only sized wrenches/sockets you will need is 12 and 14mm
