Hi! Glad to be part of the community.
I recently had the AC compressor I installed when I bought the car fail. Looking back, I think it happened because I was inexperienced at the time and only replaced the compressor without addressing the rest of the AC system.
This time, I wanted to do it correctly, so I replaced the AC compressor, condenser, and both the front and rear expansion valves. I also thoroughly flushed the AC lines and made sure any debris or old fluid was removed. I replaced the PAG oil for the entire system as mentioned before on this forum (i think around 9 fl oz total).
After vacuuming the system, it held vacuum properly, so I vacuumed more and proceeded with charging it. I added the refrigerant amount listed on the under-hood sticker, but my pressure readings are slightly higher than what the FSM specifies. The AC cools properly, though.
I know the FSM provides different diagnostic scenarios, but mine doesn’t seem to match any of them — both the low and high side pressures are a little higher than spec, yet cooling performance is good and there are no bubbles visible in the sight glass. For reference, the ambient temperature here is around 70°F and humid. I attached a photo of my gauge readings along with the FSM chart for comparison.
Has anyone experienced something similar? Am I okay to continue using the AC as-is even with the slightly elevated low- and high-side pressures?
Thanks!
Thanks!
