Changed head gasket, truck wont start?
yea once a long time ago when i was a kid, there is a huge tower at the top that we peed off of, I need to hit it up again though. thats awsome that you know of it
tallest point between the rocky's and the ocean
Do a 3 point timing test for #1 TDC...................#1 pull valve cover turn motor set harmonic balancer to 0(zero) #2 check for the triangle on the first cam bearing to line up with the notched tooth on cam gear(if not turn harmonic once and check again ....4 cycle motors mean crank hits #1 TDC twice per cam rotation on compression and exhaust stroke you want the compression stroke) so now that you have the harmonic and the cam gear perfect(if not your timing chain slipped a tooth while you had the head off) #3pull dist cap and the rotor should be pointing at the #1 electrode......if this is all right you dont have a timing problem and you can move on to the fun stuff like electronic BS!!!!
