Changed ECU - windows and locks quit working
Florida
The title says it all. I changed the ECU for a reason I posted a while back. That didn't fix the problem I was experiencing (trouble codes 83, 84, and 85 I think) so I switched the ECU's back. Then the freaking windows, locks and sunrood quit working. WTF? Anybody got any experience with this? Thanks.
Well, I've made a little headway here. I found a fusible link in the dash fuse panel that was blown. It was the 30amp "POWER" link in the bottom right corner of the panel. So I went and got another one and put it in and "POP!" it blew. So I switched the ECU boxes out and went and got another fusible link. As soon as I put in it blew. So, I have switched the ECU's back so that the new on is again in the truck, spent $6.00 on fusible links, and now I'm stumped. Again.
There is a short somewhere, and I don't know where to start looking, other than the wires that go to the drivers door (I have seen those short before since the drivers door is opened and closed so much). Any other suggestions are welcome.
Jonheld, your a good man. I fixed it. It was a wire that got pinched when I moved the passenger seat back for more room when I changed the ECU. I was stuck on changing the ECU as the only thing I did that might have caused the problem, and didn't think about the seat. The way I figured it out was I unplugged all the window switches and the short was still there, so next I want to the seats and when I unplugged the passenger seat I saw the short. The plug wasn't n on the retainer and that let it get in the way and get pinched. Thanks so much for your help.
