Hi Cruiser Folk-
I wanted some reassurance (or not) that I am purchasing the right equipment before I spend my 4th of July fixing my 91 LC and then not completing it before the long weekend...
Anyways, about a month ago I drained my front diff fluid and everything went well. I replaced the the diff bolt and washer thingy and filled it up to spec. After completing the job I then began to pressure wash the entire underside of the truck since it had never been done by me. The next day, I began leaking diff fluid(I think) and it hasn't stopped since. My thought was that the inner seals were bad and I have been driving on low diff fluid this whole time but am not sure.
I now am about to buy the whole gasket and seal set from either Marlin (FJ80 Knuckle Gasket & Seal Kit | Marlin Crawler, Inc.) or Cruiser Outfitters (Cruiser Outfitters)
Would love some advice from someone that has had this problem and successfully fixed it. Am I right in assuming this is probably the Inner Axle Seal? Is there anything else I should change/add? I don't have a huge budget for this fix so definitely keep that in mind that I probably won't be spending a ton but just enough to get the job done right.
Pics of the fluid leak below...
