SOLD Central MO: 2004 Lexus GX470
Central Missouri
Year
2004
  1. GX470
Mileage
201000
Color
White
201,000 Miles. Owned since 2019. No known mechanical issues. I drive it sparingly as a 3rd vehicle but I trust it to get anywhere. The Carfax indicated it was well-serviced by Lexus and most likely a AZ/STL mall crawler for most of its life. I’ve never wheeled anywhere technical.
The Bad:
The obligatory cracked dash and infamous chipping Blizzard Pearl hood paint. The hood paint is very flaky.
Upgrades since I’ve owned:
Prinsu Roof Rack
Metal Tech Pegasus rear swing-out bumper
Coastal Offroad high-clearance front bumper
White Knuckle bolt-on rock sliders
LT285/70R17 Nitto Terra Grappler G2’s with less than 5k miles on Level 8 MK6 17 x 9 wheels
3” Old Man Emu Heavy Duty Lift (2x90000, 2x2896, 2x2886, 2x60004)
Air suspension delete with Metal Tech rear coil conversion
Smittybilt X20 10k winch and shackle, under hood manual power cutoff switch
Viair 450C 100% duty cycle air compressor mounted under hood with manifold and cabin on/off switch
ProAmp 240A Alternator
Off Grid Engineering Auxiliary Battery Tray
Auxiliary/house Battery
Blue Sea Fuse Blocks and Dual Battery Switch, SBE Precision cabin switch to combine batteries (you can jump start the main battery using the auxiliary battery) and main/aux voltage display in cabin
New A/C Compressor and starter
Cobra 29 LX CB with shorty firestik and PA speaker
Various bushings replaced: track rod, upper/lower control arms, sway bar link, track arm
New front CV Axles and tie rods, timing belt and water pump at around 196k
Center diff actuator seals replaced within last year; diff locks up as it should
Dual fire extinguishers mounted inside rear doors
WeatherTech mats
Mount that will accept any Blackhawk Serpa CQC holster at base of driver seat
USA SPEC BT45-TOY Bluetooth Adapter
Dash/rear cam
Multiple key FOBs
OBDII/usb dongle if you have Techstream
Clear/clean title in hand.
$14,500 OBO. Call or text 660-676-8260
