Central diff lock..please help
Asturias(Spain)-London(England)
Website
www.sybaris-expediciones.com
Hello everyone.
I just got the automatic gearbox of my HDJ81 (japanese import) repaired and I found out that the central diff lock is not working, not with the switch in the dash neither when setting low range.
I took it to the Toyota garage that replaced my gearbox, and they spent two days making tests on it. I went today's afternoon and the answer is: we can't fix it. I couldn't belive it.
They told me they had replaced the diff lock engine with another 80's that was working properly and nothing happened, they also replaced the switch and checked all the electric system. It took them two whole days working on it!
They said as well that, when taking the engine out and moving the diff lock manually, it works and it even appears a light in the dash, and the other two diff locks start working as well. They checked that the switch is sending a signal and it sends as well (you can hear a clic when you press it), but the signal never gets to the engine.
They told me the problem must be in an electric panel between the switch and the engine, but they connected the diagnose machine and it doesn't give any error codes.
It sounds very strange to me I can't believe after two days not even they couldn't repair it, they don't know where the problem is.
Have you got any ideas?, Thank you very much.
Yes, that's what I asked them, but they say they can't think in any other think to try. A friend just mentioned me about the ECUS, anyone knows what's that and how to repair them?
Thanks
Take it to a good independent mechanic, dealers can't/won't really look for anything, they just replace whatever the diagnostics tell them is wrong. Even though the dealer probably broke whatever it is it sounds like it is going to be your problem. You can try to take the dealer the repair bill after the independent fixes the problem and if you can make them believe their previous repair caused the problem (and they said they couldn't fix it) you might be able to get somewhere.
Good luck
Rusty
Was it working before you had the tranny repaired? If it was, have your Tech go over the associated wiring along with any associated connectors that would have been disturbed during the removal/installation.
Canonero,
Did they also check the transmission relay block, Part # 89531-60010, (it is located behind the kick panel, usually under a silver box for the ABS --- this is the same box the harness goes into that you do the Pin-7 mod on). If they say the switch is providing a signal but your center diff is not locking this could be the culprit. If they haven't could they not put a relay block from a working LC and troubleshoot it that way?
Another possibility is the switches that are on the transfer case, mianly the one in the 11 to 12 o'clock positon. These will stick due to lack of use. There are several writeups on how to troubleshoot and repair this. Here is a link to a thread: https://forum.ih8mud.com/showthread.php?t=176658
Hope this helps,
Glen
Thanks a lot everyone.
I'll translate all your ideas and send them to the Toyota dealer. Unfortunately, they won't accept paying the bill of another mechanic, they want to fix it by themselves (I hope they can, they don't know much about 80 series).
I just had an idea, if this doesn't work. Since the diff lock engine works when pluging electricity and the light in the dash turns on, why not connecting a switch straight to the diff lock engine without going through any ecu?.
I may be talking bull**** (I don't know anything about mechanics), but, what do you think?
