Center spiral cable
Malleus
contact@Restore4x4.com
Supporting Vendor
Charlotte, NC
After removing my steering wheel and reinstalling it, neither the horn nor cruise works. The problem is definitely in the spiral cable; I can bypass the connectors on either side and make the connection.
Anyone have any experience with these things dying? Or, failing that, useful words of wisdom on how to get this thing working again?
I wish i could help you out but don't have the experience and couldn't figure out how to open things up and see what was wrong when I was having trouble with my combination switch . For me the turn signal failed (it wasn't the relay solenoid) but everything else worked fine. I ended up replacing the unit ($$) but fixed the problem that way. I still have the old switch assembly and may mess around with it some day if I have some spare time. The best I can do is give your post a bump and let you know that i had something with the switch fail so it can happen.
