Center diff. operation
How does the CD actually work when it is in 4 hi and not in "CD lock" mode? Does it work like a standard open rear diff.? In a typical rear open diff., it will put the power to the wheel that has least traction and you can get stuck with just one wheel spinning. When in 4 hi, does the center diff operate like this? In other words, is it possible to get stuck (in 4 hi) with ONLY the front OR rear spinning, or does it operate like a standard 4WD and whenever you get stuck, you will ALWAYS at least have one front and one rear tire spinning (when no lockers are engaged)??
I've read that before. That was what peaked my curiosity. It does not say specifically, but it sounds like you can get stuck with one tire spinning in 4 hi. "In our situation here, instead of all traction being lost to the spinning wheel..........."
My CDL is still not working. I've tried bumping it hard into 4lo several times and driving in circles and figure 8's, but still no workie. I guess I'll try replacing the switch on the t case. I was just trying to figure out if I actually just have a 2wd right now until I get my CDL working.
You got it right on the money there.
When the CDL is unlocked, it acts just like a regular open differential, allowing the F/R driveshafts to turn at different speeds. Basically AWD. And when locked, it acts just like a PT 4WD truck.
And with 3 open diffs (F/R/CDL), you can spin just one wheel.
so what sort of drive do you get when it isn't engaged? AWD? Power is going to only 1 front (w/ the most grip) and 1 rear tire (w/ the most grip)?
No, least!
*somewhat* limits slip (when the center diff is not locked).
I say somewhat because, for example, if you removed the front driveshaft and tried to drive the vehicle (with the center diff. unlocked) the viscous coupler would *not* completely compensate, and you would in fact *not* be able to drive anywhere.
Curtis
YouTube - Around the Corner
YouTube - Eaton Locking Differential Demonstration
YouTube - Silverado with Locking Differential (G80)
YouTube - Toyota Tundra vs GMC Sierra - Off Road Traction
https://forum.ih8mud.com/80-series-tech/196420-im-looking-96-lx450-central-diff-lock-button.html
To answer your question -- full 4WD is only when the CD is locked. Stock configuration locks the CD in 4LO only. To lock the CD in 4HI you need to do the 'pin 7' mod and add a switch. Then you can manually lock the CD in HI range.
Factory lockers only engage when the CD is locked.
M
M
Minor correction:
Stock configuration locks the CDL automatically in LO. The Pin 7 mod allows you to unlock in LO. Adding just the switch allows you to lock in HI.
Why would you need to unlock in Lo?
To still have the advantage of the low gearing in high traction areas while making it easier to maneuver without the drive train binding up in tight situations? Like tight switchbacks for instance where being able to turn just a little tighter may mean not having to stop and back up to make the turn.
Those that have done the pin-7 mod seem to love it...I haven't done the mod, yet.
In case it isn't obvious you can do the CDL switch mod apart from the pin-7 mod but if you do the pin-7 mod without the CDL switch...Well :doh:
Oh, and adding the CDL allows you to lock your front and rear diffs in H is you desire and are so equipped. Comes in handy when I go out just to exercise the lockers.
So let me see if I have this right. Let me start off by saying I do not have fr/rr diff locks.
I do have the CDL switch factory installed. Since my center diff. will lock in 4lo I don't have to push the switch. The switch is only for locking Center diff in 4hi.
Yep, you got it right. I don't imagine you get much snow down in AL :D, but around here locking the center diff in H can make a world of difference in driving around in the white stuff.
Offroad wise well...The 80 is a heavy beast and unless you're just driving around on relatively flat dirt road locking the 80 while in H doesn't buy you much...Offroad you start needing the lower gearing.
Appreciate the info Lka1988, Mike S, Corsair23. I've read about the pin7 mod (but never realised I only have 2WD since my CDL's not working), I'll have to bump that up a few notches on my (long) to-do list. Thanks again for the help guys!
I think we may have confused you? :confused:
The 80 is AWD, all the time (think Subaru) unless you have a non-USA version or do a PT 4WD conversion.
The CD acts like the front and rear diffs that send the power to the wheels in that it sends power to the front and rear axles somewhat equally, or unequally, depending up the situation, and allows for the 80 to run around in AWD without binding up (like what would happen if you put a PT 4WD rig in 4WD and drove around on pavement).
The CDL simply "locks" the front and rears axles 'together' so they theoretically get a constant 50/50 split of the power available regardless of what wheels have traction etc. This way, if one tire comes off the ground (say front right), not all of the power available will go there and be useless to you. If you were to remove the front or rear driveshaft leaving the other one in, and then try to drive around your 80 without the CD locked, it would sit there motionless as all of the available power takes the path of least resistance which would be toward the missing drive shaft. Lock the CD and do the same and the 80 will move.
Think of the CD in a similar way as your axles, only sitting horizontal to instead of perpendicular to the path of travel.
In your original post you pretty much had it right but no one came out and said that clearly - They provided helpful links to other threads etc. where this issue has been explained in depth. The post above this mentions the VC which can help but just like a limited slip rear diff, it may not solve a low traction problem. Some people have even removed their VC.
HTH
corsair: Thanks for the additional info. No, you haven't confused me. I realize that there is power going to the front and rear somewhat equally (or unequally) all the time. However, when in 4hi, if you can get stuck with just one tire spinning, that's basically a 2wd to me. Until I starting researching the CD and the way the 3 open diff.'s operate (in 4 hi) I assumed if I ever got stuck in 4hi (while my CDL is inoperable), I would at least have one tire spinning up front and one tire spinning in back. From what I understand now, to have true 4wd capability, I need to do the pin 7 mod and or get my CDL operating (unstuck). Thanks again for the help.
Ding ding ding ding ding, we have a WINNER!! What do we have for him, Johnny?
BTW: Get the CDL switch BEFORE you do the Pin 7 mod. :cheers:
Almost there :D
To have true 4WD capability you do need to have the CDL working - that is correct.
However, you do NOT need to do the pin-7 mod and you may not want to! What the pin-7 mod allows you to do is to unlock your CD while in low range. By default on a stock 80/LX450 when you shift the CD (tcase) into low range it "should" automatically lock the CD. With a CDL switch and the pin-7 mod you have complete control over if and when the CD locks regarless of whether you're in H or L range. The mod removes the wire (some people cut it) from pin-7 on the connector that sends the signal to lock the CD when you shift into low.
HTH :cheers:
