I am nearing the end of week two of owning a 94 land cruiser with elockers and starting to chase down why the center diff is not activating. Here is the state of the cruiser presently and which paths I have tried to remedy the truck.
On start up the abs, front locker, rear locker light come on and go out as they should.
At this same time, shouldn't the center locker light come on as well?
When shifting to low range neither the abs, nor the center diff lights come on and I do not hear any audible actuator noise.
Also the abs kicks on right before coming to a stop, but the dash light does not come on during this event.
-So I have cleaned the abs sensors and the front reluctor wheels to improve the stutter stop. Also check the resistances and continuity on the sensors and they checked out fine.
- I checked all of the fuses by the battery and in the dash mounted panel, none were blown.
- I pulled the diff lock switch from the transfer case, cleaned the ball, cycled it, checked continuity and resistance, it passed but still no locking.
- Back under the truck I found the L4 sensor wire was not connected to the sensor, naturally connected it back up, still no locking.
- I pulled transmission relay (which I hope is the same as the diff relay), followed the test procedure and the relay checks out.
- I am at the point of pulling the actuator connector apart to test the resistance, but it feels like it's glued together.
What other areas should I check?
