Center Diff Lock Button
Camden, SC
I purchased my LC about 5 years ago and it was missing the front drive shaft. Shortly after the purchase I installed a front drive shaft. I can now engage or disengage the CDL button and can't tell any difference at all in performance. In addition to no noticeable difference, the light stays on when CDL button is in or out. Could it be that it was hard wired in the engaged position when the PO did not have a front drive shaft? How can I tell if it's engaging or disengaging?
Tight turns on asphalt should produce a heavy feel in the steering and you may hear the tires gripping more aggressively.
Select the disengaged position, remove front shaft, go for test drive. You will know if the center dif is unlocked when the vehicle does not accelerate or climb grades properly. Forward motion will not be proportionate to gas input or possibly zero.
Last year I removed my front shaft for mods. A couple days later I jumped in to go downtown. No problem downhill to the stop sign but after I made the turn and started up the slight grade to exit my neighborhood the tach climbed but I slowed. Felt like it was struggling. Chances are that the PO hard wired it locked.
