Center Console Idea-- Will this work
Dallas, TX
Any thoughts on if a center console from a Ford F150 will fit into the 80 between the seats and still have room for the e-brake?
Dimensions:
L 28 / H 16 / W 11
It would be interesting to see if it fits. If you've got the one pictured, give it a try.
It might fit. I purchased the Smittybilt box that some folks here recommended. http://www.amazon.com/gp/product/B001CF19TS?tag=ihco-20
I have not installed it yet. But the dimensions are 24Lx14Hx11W I don't know if that last 2 inches of length will be critical for folding the rear seats or not.
Your F150 option definitely seems viable. Any more details on the F150? Year, trim level, cab size?
That's actually a good looking console...
If it helps I have those 3D cup holders that hang out the back & barely fit the seats folded up. So there is room in the rear. Put in & take a bunch of pics for historical purpose. If you get in there this mod will go on my short list of mods to do.
I havent bought it yet and wanted to see if you guys think the dimensions would work. If we think they will work, I will buy one and see.
:doh::bang: don't laugh.
I'm in my work truck right now. It's a 2009 F150... After looking at it it's big... I think to big. I just measured off a fat 11" here's a pic.
thanks guys.
@GW Nugget--- What about the length? can you measure and compare to the cruiser to see how far back it will go?
Does anyone have the actual width measurement in an 80 between the front seats? I am also thinking 11" may be a bit too wide as well......
Unlikely to clear the ebrake. I have a 8" wide Tuffy. Pushed to the passenger side as much as possible (it's a little tight over there now for me, I'm a big guy, but wife is fine) there is just enough room to comfortably grab and use the ebrake.
Overall length does have a max value due to the folding seats, but less than that does let you move the unit fore and aft to best mounting position for your use.
@greentruck --what is the length of the Tuffy box?
Couldn't the parking break be reconfigured into some kind of wire-pull or something else, a crank even? or deleted?
I rarely use mine, only when I put my truck on a jack, but my ebrake is pretty weak at the moment. Just curious if it could be deleted or it that's one of those inspection items that is a no-go or that I'm missing something entirely (I also have chocks in my truck).
Citadel,
I have the version with the radio mount. It's not quite 21" long. A cupholder comes with it that is about 5" longer when attached to the back of the Tuffy, although it's usually set up at the front by the tranny lever. I've got a bad shoulder, so pushed the main box forward with my mount so the elbow rest is right for me. When folded, the rear seat barely clears or is right up against the cupholder
Yes, you can reconfigure. In fact, there's an indent under the dash where just such a lever might go (to right of steering wheel) and several others here have done a relocation by various means. The handle assembly is very common in minitrucks and there may even by a JDM LandCruiser version?
Not a good choice to delete it, though. Probably not legal, but you do have to be in Neutral to shift to low range in an unmodded vehicle. Sure the foot brake works, but...Still a good idea to get it to work, too, unless you carry around a block to throw under the wheel on hillso_O
Length noted in previous post. One good thing about the 8" Tuffy, even though it has to be shfted to the right to clear the ebrake. That also opens up another space between the driver's seat and the Tuffy, but behind the e-brake that is handy to mount a radio in. That's where I have my CB. So it's not wasted space. Alternatively, a cup holder may work, a skinny wastebasket, etc.
Could it be shortened and integrated to the interior of the box?
@greentruck --Would you say then that 21" is the max length for the center console to be able to still fold down the rear seats?
Citadel,
No, overall w/ cupholder is ~26". And with the front of the box with an 1" or 2" of the shift console, the 2nd row will still fold. That leaves the back of the cupholder/box (depending on which way it's assembled) just even with the back of the front seats all the way back. Or you could omit the cupholder and use that space some other way.
You can squeeze a lot of stuff in if you try...
The side view:
The brown pad is from Tuffy. The green is something I added for my elbow. It's the padded foam from inside a 120mm HEAT round container. Good stuff, if you can find it.
I mentioned mine is situated further forward than is typical to give my shoulder support. If you have long arms like me, you do need to be careful to not flail the right elbow way out when steering, as it's possible to smack it on the Tuffy. Only needed to do that once...:doh::crybaby:
BTW, drilling holes in the Tuffy to mount stuff isn't easy. It really is darn hard stuff. Something to keep in mind. Get the good bits out...
Not a good idea. The Tuffy lid is heavy -- it's secure. You can't just flip it open in an emergency. Plasticky ones, maybe, but I wouldn't want to explain how the truck ended up in the water at the boat ramp to my insurance company if I had one set up like that. YMMV;)
BTW, the relocates I remember were pretty simple, so may be worth searching them up if that sounded like :banana::banana::banana: work. Seemed simpler, but maybe it's just my CRS?:hillbilly:
