04/95 LC OBDI
A couple years ago I managed to pull ABS fault codes.
For some time now I haven't been able to pull any codes at all. Lost my touch I guess.
Just replaced the short block, main engine wire harness, had the head reworked and am getting a CEL. I've pulled the 15 amp EFI fuse and or the battery for 15 mins. ECU relearns after about 15-20 miles and 5-7 restarts and CEL returns. However, I can't pull any codes.
I can set the base timing, just as I could before the new parts, with E1 and TE1 jumped in the diagnostic port. Pull the jumper and ECU takes over and adjusts the timing. Confirmed with timing gun.
However, I can't pull any codes even though the CEL is lit while truck is running.
Here is what I do in an attempt to pull code/codes:
Engine off
Jump E1 TE1 in diagnostic port on firewall.
Pull the very small jumper in the diagnostic port. (tried not pulling that small jumper with same result)
Turn key to the "on" position.
Results in solid CEL light with no blinking.
Would you all fine people help me get this worked out please?
Thanks,
Ed
Engine off
Thanks,
Ed
