cdl
Not in stock format.
Search for the "7 pin mod"
I believe the 'Pin 7' mod only allows you disconnect the CDL when you are in low range. If you have a CDL switch on your dash then you can engage the CDL in high range. I have never seen any mod that allows the front or rear lockers to be engaged in high range but I can't think of a reason why I would need that anyway.
The only requirement to engage front and rear factory lockers is that the CDL dash indicator shows locked.
Adding the dash switch allows for locking the CDL high range on 93 and up model years. 91-92 models came with the dash switch from the factory. Doing the Pin 7 mod (not the 7 Pin mod:bang:) disables the functionality of locking the CDL by shifting to low range making the dash switch the only thing that controls the CDL locking in either high or low range.
Yeah a CDL switch is implied in the 7 pin mod, otherwise how would you lock the center diff after you disconnect pin 7? With a CDL switch you can engage front and rear lockers in high, but you'd have to be going 5 MPH or less.
This was answered in the other thread the OP started under the same title.
As long as the CD is locked, the axle lockers will function. If you do the pin 7 mod, you can lock the CD while in H, hence allowing you to lock the axle diffs while in H.
The pin 7 mod removes the CDL function from the transfer case shift and puts contol to the driver. You can shift to L and not have the CD automatically lock; its not about disabling the CD, it about enabling it only when you want it enabled.
