CDL will not engage-Help
Orange County, CA
I bought a 1997 80 series 1 month ago and I can not get the CDL to engage by shifting the transfer case.
I should receive FSM any day, I hope that will help!
I have searched the forums within this and other sites and I still have a few questions that I have not been asked before.
In review of "Troubleshooting FJ80 Land Cruiser Center Diff Lock (CDL)" posted on Pacific Northwest Backroad Adventures site.
  • I have checked all of the fuses inside and under the hood.
  • Per the PNWBA, I have tested all of parts- only the Transmission relay did not pass, it was replaced.
  • Used the 9 volt to activate the CDL Actuation Motor, it worked.
1. I have tested the L-4 and Transfer Neutral switches, they both have no continuity open, and continuity when closed or depressed. When I use a paper clip to jump neither dash light comes on, would this be an issue with the Transmission rely or wires/harnesses?
2. I have used a 9volt battery and engaged the CDL actuator motor ran and stpped, I tested this by lifting the front end off the ground and this work to lock CDL / front and rear drive shafts, I have replaced the Transmission Relay and still nothing happens, it is as if there is no power going to the Trans Relay?
3. When shifting the tranfer case I do not hear the Transmission Relay making the clicking sound, what I'm I missing here?
Any help would be appreciated.
I would look through your wiring diagram and test continuity of the wires in the harness coming out of the transmission control relay (in the left kick panel). This is the box that controls the CDL operation, be it manual or automatically when the truck is put in LOW. It is possible that either this box (is this the box you replaced?) or the wiring leaving it to the transfer case is damaged.
Here's a link to another post that might help: https://forum.ih8mud.com/80-series-tech/176658-center-diff-lock.html
Here's slee's pin-7 instructions that identifies the box I'm talking about as the Transmission Control Relay
-Phil
Based on reading your post again, I would focus your testing on the following:
- Use a meter and the wiring diagram to ensure that power is going TO the TCR (transmission control relay) in the DS kick panel.
- Once that is OK, test continuity for each of the wires going to the center diff/TC from this box - it is possible that the wiring harness is damaged or melted.
Phil
I fixed a 94" last night with the same problem.
In that case the wires from the position switches on the top of the transfer case were in two.
Have you tested the two wires from that switch to the Transmission relay? They should give ground to the transmission relay to let "tell" if the Diff lock is on or off. Other one is green/black an the other green/yellow.
When turning the motor with a 9 volt battery you should be able to to measure these wires with a test lamp or a multimeter. Remember they are supposed to feed ground to the transmission relay.
I had to go under the truck, find those two wires (green and yellow). They come from a lid next to the diff lock actuator motor on the top of the transfer case. Then soldier them together. In this case the transmission and the transfer case have recently been lowered and the wires must have damaged. The truck I was working on has a 7 cm bodylift so it was quite easy to see and reach the wires but I´m sure it is a pain in the a... on a stock truck.
This is a capture from the wiring diagram, hope it will help :beer:
