CDL Switch Relocation
Southeastern VA
I just got my CDL Switch in the mail today (from CDan) and I went to install it tonight. Pulled the center dash in about 30 seconds, found the connector (which has a very short lead on it), plug in the switch to the harness to test before I start moving things around, works fine, all is well. At this point I start looking into how and where to put it. It appears from the length of the leads from the harness that it was meant to go right where the factory alarm light/sensor resides, and of course, there is no spare room on the wires for the factory alarm sensor to move it either. I looked into moving the rear defrost and hazard light to the bottom row of switch blanks but they are also too short. At this point, I figure I might as well move the CDL switch to the left side of the wheel near where the factory FR/RR locker switch will be going. I would like to use the plastic connectors instead of spices and heat shrink protectors but I have done zero automotive wiring and very little of any other type of wiring. What seems to make sense is to attach a female connector to the switch harness connector and then run that female with about 24 inches of wiring to another male that will plug into the switch on the far side of the wheel. Does this make sense?
Now to my question(s):
1) What connectors will I need?
2) What size wires to make this work?
3) Where do I find these parts; are they available at Radio Shack or do they need to be ordered online?
Any assistance would be appreciated.
Thanks
You can also use mechanical crimp connectors that are easier than soldering. You can go in and ask anyone in Radio Shack or another electronics store what you need, and they'll be happy to show you. Of course, if you're spending more than a couple of bucks (assuming you have all the tools), then you're spending too much.
I just moved the antenna control to the lower row, and dropped the CDL switch in the top row. No front/rear lockers for me though. :meh:
As I have researched it a bit more it looks like I will probably go with the crimp connectors. I have worked with them before. I will probably also just keep it in the center to make things easier.
Thanks for the info.
Just FYI - I was able to remove the old electrical-tape-like wrap on the harness and separate it a little to put it in the top middle of the dash without rewiring
x2
I relocated the antenna control switch to the bottom row by the rear heater (hardly if ever touch it). Then I moved the alarm dealyo over and put the CDL switch there. I might have moved the other switches up there as well...
My set up on the top row is: CDL, alarm dealyo, rear defrost, hazard switch
I thought about putting the CDL switch over with the fr/rr locker switch but it wasn't worth the work IMO. Maybe someday.
Anyway, if you simply remove some of the wrapping on the harness you should not have any need to cut/solder/crimp any wires.
:cheers:
I had not thought of removing the harness binding. That should definitely give it a bit more room. Thanks.
That is what I did when I installed mine.
I put mine just above the A/C buttons all the way to the left where the glass breakage mic. used to reside.
Moved the glass break detector to the left of the steering wheel.
Did you find that there was enough stock wiring to move the security sensor to the left of the drivers side? That seems like a logical place for it as well.
Yes.
The CDL harness is short, so you are limited where you can put it without adding wire.
But, the security sensor lead was quite long (on my 97), just required that I peel back some of the tape/binding in order to move it.
Thanks
How did you pull the center dash?
Thanks
Thanks
Funny, because I just did the CDL switch this last weekend. To remove the center dash, pull out the ash tray and you will see 2 scews - remove these. Then, above the radio is the liitle thin storage area, inside of this on the top are 2 tabs. Gently depress the 2 tabs and it will come out. You will see 2 screws in there as well and once removed, the dash will now pop out. Good luck!
Sweet. Thanks for the info...
